remote telnet scripts?
no one you have on hand scrips telnet the remote?
thanks.
I can give the scripts to the remote telnet vu + if possible?
thanks.
I don't understand what you need.
Do you want do connect your vu+ telnet from remote?
In your lan forward port 23 of your router to your vu+ ip and digit:
telnet dyn-dns_address
I put a script in a pluguin to get me through the menu pluguins and Ireturn to the previous screen after running, so the scripts of theremote, and step and I have to do my experiments , jejeje
Greetings.
