Dokuos
Hello everyone
I'm trying to remove this plugin, because we use the Solo SE like a digital signage player and need no to power off.
If I disable the Autoshutdown, works ok, but at night, the electricity is off, and next day the settings are again with AutoShutdown enable.
When I go to remove the pluing, I can't because have some dependencies.....
Can I remove this plugin?
Can I change the default values?
Thank you very much
Thank you very much
