Repeated crashing and other issues
NinjaFromNZ
Running OBH Version = 4.3.026 on a VuPlus Duo4k
Whenever I try to scan satellite feeds, it refuses to, saying scan failed
DVB-T works reliably
From time to time, DVB-S channels show a black screen until I restart Enigma2 or reboot the box
When the DVB-S channels are in this mode, the timers are initiated, but nothing gets recorded
Running a full backup, it gets to 46% then stalls. It never completes
Running EPG Import, the System crashes (crashlog below)
I get errors from time to time saying "sory: timeout" (I can't remember the exact message bur searching for it online returned a possible HDD issue - I'm not sure if the crashlog supports it being an HDD issue)
Any advice appreciated
Crash log below
OpenBh Enigma2 Crashlog
Crashdate = Thu Nov 5 11:21:16 2020
Creator = OpenBH
Version = 4.3
Build = 026
Type = release
Machine = vuduo4k
URL = http://www.vuplus-community.net
Compiled = Apr 23 2020
Skin = Waves4_weather/skin.xml
Component = enigma2, signal
Kernel CMDline = libata.force=1:3.0G,2:3.0G,3:3.0G root=/dev/mmcblk0p9 rootfstype=ext4 rootflags=data=journal rootwait rw coherent_pool=2M vmalloc=500m bmem=891m@1156m bmem=575m@3520m
Nim Sockets = NIM Socket 0:
Type: DVB-S2X
Name: Vuplus DVB-S NIM(45308X FBC)
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2X
Frontend_Device: 1
NIM Socket 2:
Type: DVB-S2X
Frontend_Device: 2
NIM Socket 3:
Type: DVB-S2X
Frontend_Device: 3
NIM Socket 4:
Type: DVB-S2X
Frontend_Device: 4
NIM Socket 5:
Type: DVB-S2X
Frontend_Device: 5
NIM Socket 6:
Type: DVB-S2X
Frontend_Device: 6
NIM Socket 7:
Type: DVB-S2X
Frontend_Device: 7
NIM Socket 8:
Type: DVB-T2
Name: Vuplus DVB-T NIM(BCM3466)
Mode 0: DVB-T2
Mode 1: DVB-C
Frontend_Device: 8
I2C_Device: 4
NIM Socket 9:
Type: DVB-T2
Mode 0: DVB-T2
Mode 1: DVB-C
Frontend_Device: 9
I2C_Device: 4
f, m_tuning 1
< 582.1043> 11:20:59.0264 [eDVBFrontend2] sleep 500ms
< 582.1801> 11:20:59.1022 [eDVBFrontend2] fe event: status 7, inversion off, m_tuning 2
< 582.5267> 11:20:59.4488 [eInputDeviceInit] 1 160 1
< 582.5272> 11:20:59.4494 [InfoBarGenerics] KEY: 352 OK
< 582.5276> 11:20:59.4497 [ActionMap] Keymap 'OkCancelActions' -> Action = 'ok'.
< 582.5385> 11:20:59.4607 [Skin] Processing screen 'Menu' from list 'menu_av, Menu', position=(0, 0), size=(1920 x 1080) for module 'Menu'.
< 582.5555> 11:20:59.4777 [Skin] Processing screen 'MenuSummary', position=(0, 0), size=(480 x 320) for module 'MenuSummary'.
< 582.5818> 11:20:59.5039 [eDVBFrontend0] fe event: status 1f, inversion off, m_tuning 0
< 582.6065> 11:20:59.5286 [eDVBFrontend2] set dynamic current limiting
< 582.7561> 11:20:59.6782 [eInputDeviceInit] 0 160 1
< 582.7564> 11:20:59.6786 [InfoBarGenerics] KEY: 352 OK
< 585.3933> 11:21:02.3155 [gAccel] alloc failed
< 585.3934> 11:21:02.3155 [gSurface] ERROR: accelAlloc failed
< 585.4246> 11:21:02.3467 [eInputDeviceInit] 1 ae 1
< 585.4252> 11:21:02.3473 [InfoBarGenerics] KEY: 174 EXIT
< 585.4256> 11:21:02.3477 [ActionMap] Keymap 'OkCancelActions' -> Action = 'cancel'.
< 585.6562> 11:21:02.5783 [eInputDeviceInit] 0 ae 1
< 585.6567> 11:21:02.5788 [InfoBarGenerics] KEY: 174 EXIT
< 586.7612> 11:21:03.6834 [eInputDeviceInit] 1 6c 1
< 586.7616> 11:21:03.6837 [InfoBarGenerics] KEY: 108 DOWN
< 586.9930> 11:21:03.9151 [eInputDeviceInit] 0 6c 1
< 586.9936> 11:21:03.9157 [InfoBarGenerics] KEY: 108 DOWN
< 587.1042> 11:21:04.0264 [eDVBChannel] OURSTATE: failed, retune
< 587.1043> 11:21:04.0264 [eDVBFrontend2] tune
< 587.1043> 11:21:04.0264 [eDVBSatelliteEquipmentControl] [prepare] UnicableTuningWord 0xd11, guard_offset 0
< 587.1043> 11:21:04.0264 **** Tuning Unicable
< 587.1043> 11:21:04.0264 **** frequency_mhz: 12581
< 587.1043> 11:21:04.0264 **** lo_mhz: 11300
< 587.1043> 11:21:04.0265 **** ub_mhz: 1210
< 587.1043> 11:21:04.0265 **** T: 273
< 587.1043> 11:21:04.0265 **** ub: 0
< 587.1043> 11:21:04.0265 **** position: 0
< 587.1043> 11:21:04.0265 **** mode: 3
< 587.1044> 11:21:04.0265 **** bank: 3
< 587.1044> 11:21:04.0265 **** Unicable: e0 10 5a 0d 11
< 587.1044> 11:21:04.0265 **** Calculated tuningword: 0d11
< 587.1044> 11:21:04.0265 **** Stored tuningword: 0d11
< 587.1044> 11:21:04.0265 [eDVBSatelliteEquipmentControl] RotorCmd ffffffff, lastRotorCmd ffffffff
< 587.1044> 11:21:04.0265 [eDVBFrontend2] prepare_sat System 1 Freq 12581000 Pol 0 SR 22500000 INV 2 FEC 2 orbpos 1600 system 1 modulation 2 pilot 2, rolloff 0, is_id -1, pls_mode 1, pls_code 0, t2mi_plp_id -1 t2mi_pid 4096
< 587.1044> 11:21:04.0265 [eDVBFrontend2] tuning to 1211 mhz
< 587.1044> 11:21:04.0265 [eDVBChannel] OURSTATE: tuning
< 587.1044> 11:21:04.0266 [eDVBServicePMTHandler] tune failed.
< 587.1045> 11:21:04.0266 [eDVBServicePlay] DVB service failed to tune - error 1
< 587.1049> 11:21:04.0270 [eDVBServicePMTHandler] ignore sdt update data.... incorrect transponder tuned!!!
< 587.1049> 11:21:04.0271 [eDVBServicePMTHandler] incorrect namespace. expected: 6400000 current: ffffffff
< 587.1049> 11:21:04.0271 [eDVBServicePMTHandler] incorrect transport_stream_id. expected: 1 current: ffffffff
< 587.1049> 11:21:04.0271 [eDVBServicePMTHandler] incorrect original_network_id. expected: a9 current: ffffffff
< 587.1051> 11:21:04.0272 [eDVBFrontend2] set static current limiting
< 587.1051> 11:21:04.0272 [eDVBFrontend2] invalidate current switch params
< 587.1051> 11:21:04.0273 [eDVBFrontend2] set sequence pos 3
< 587.1051> 11:21:04.0273 [eDVBFrontend2] setVoltage 2
< 587.1244> 11:21:04.0465 [eDVBFrontend2] setTone 0
< 587.1368> 11:21:04.0589 [eDVBFrontend2] sleep 75ms
< 587.1817> 11:21:04.1038 [eInputDeviceInit] 1 160 1
< 587.1822> 11:21:04.1044 [InfoBarGenerics] KEY: 352 OK
< 587.1826> 11:21:04.1047 [ActionMap] Keymap 'OkCancelActions' -> Action = 'ok'.
< 587.1982> 11:21:04.1203 [Skin] Processing screen 'menu_scan' from list 'menu_scan, Menu', position=(0, 0), size=(1920 x 1080) for module 'Menu'.
< 587.2101> 11:21:04.1322 [Skin] Processing screen 'MenuSummary', position=(0, 0), size=(480 x 320) for module 'MenuSummary'.
< 587.3006> 11:21:04.2227 [eDVBFrontend2] sendDiseqc: e0105a0d11(?)
< 587.3019> 11:21:04.2240 [eDVBFrontend2] sleep 150ms
< 587.3837> 11:21:04.3059 [eDVBFrontend0] fe event: status 1f, inversion off, m_tuning 0
< 587.4130> 11:21:04.3352 [eInputDeviceInit] 0 160 1
< 587.4136> 11:21:04.3357 [InfoBarGenerics] KEY: 352 OK
< 587.4519> 11:21:04.3741 [eDVBFrontend2] setVoltage 1
< 587.4639> 11:21:04.3861 [eDVBFrontend2] update current switch params
< 587.4640> 11:21:04.3861 [eDVBFrontend2] startTuneTimeout 5000
< 587.4640> 11:21:04.3861 [eDVBFrontend2] setFrontend 1
< 587.4640> 11:21:04.3862 [eDVBFrontend2] setting frontend
< 587.4641> 11:21:04.3862 [eDVBFrontend2] fe event: status 0, inversion off, m_tuning 1
< 587.4641> 11:21:04.3862 [eDVBFrontend2] sleep 500ms
< 587.5359> 11:21:04.4580 [eDVBFrontend2] fe event: status 7, inversion off, m_tuning 2
< 587.9642> 11:21:04.8864 [eDVBFrontend2] set dynamic current limiting
< 588.3810> 11:21:05.3032 [eDVBFrontend0] fe event: status 1f, inversion off, m_tuning 0
< 588.4944> 11:21:05.4166 [eInputDeviceInit] 1 ae 1
< 588.4950> 11:21:05.4171 [InfoBarGenerics] KEY: 174 EXIT
< 588.4954> 11:21:05.4176 [ActionMap] Keymap 'OkCancelActions' -> Action = 'cancel'.
< 588.7262> 11:21:05.6483 [eInputDeviceInit] 0 ae 1
< 588.7269> 11:21:05.6490 [InfoBarGenerics] KEY: 174 EXIT
< 590.0647> 11:21:06.9869 [eInputDeviceInit] 1 6c 1
< 590.0653> 11:21:06.9874 [InfoBarGenerics] KEY: 108 DOWN
< 590.2950> 11:21:07.2171 [eInputDeviceInit] 0 6c 1
< 590.2955> 11:21:07.2177 [InfoBarGenerics] KEY: 108 DOWN
< 590.5446> 11:21:07.4668 [eInputDeviceInit] 1 160 1
< 590.5451> 11:21:07.4672 [InfoBarGenerics] KEY: 352 OK
< 590.5454> 11:21:07.4675 [ActionMap] Keymap 'OkCancelActions' -> Action = 'ok'.
< 590.5943> 11:21:07.5164 [Skin] Processing screen 'Menu' from list 'menu_epg, Menu', position=(0, 0), size=(1920 x 1080) for module 'Menu'.
< 590.6035> 11:21:07.5256 [Skin] Processing screen 'MenuSummary', position=(0, 0), size=(480 x 320) for module 'MenuSummary'.
< 590.7761> 11:21:07.6982 [eInputDeviceInit] 0 160 1
< 590.7766> 11:21:07.6987 [InfoBarGenerics] KEY: 352 OK
< 592.4640> 11:21:09.3861 [eDVBChannel] OURSTATE: failed, retune
< 592.4641> 11:21:09.3862 [eDVBFrontend2] tune
< 592.4641> 11:21:09.3862 [eDVBSatelliteEquipmentControl] [prepare] UnicableTuningWord 0xd11, guard_offset 0
< 592.4641> 11:21:09.3862 **** Tuning Unicable
< 592.4641> 11:21:09.3862 **** frequency_mhz: 12581
< 592.4641> 11:21:09.3862 **** lo_mhz: 11300
< 592.4641> 11:21:09.3862 **** ub_mhz: 1210
< 592.4641> 11:21:09.3862 **** T: 273
< 592.4641> 11:21:09.3863 **** ub: 0
< 592.4641> 11:21:09.3863 **** position: 0
< 592.4641> 11:21:09.3863 **** mode: 3
< 592.4641> 11:21:09.3863 **** bank: 3
< 592.4642> 11:21:09.3863 **** Unicable: e0 10 5a 0d 11
< 592.4642> 11:21:09.3863 **** Calculated tuningword: 0d11
< 592.4642> 11:21:09.3863 **** Stored tuningword: 0d11
< 592.4642> 11:21:09.3863 [eDVBSatelliteEquipmentControl] RotorCmd ffffffff, lastRotorCmd ffffffff
< 592.4642> 11:21:09.3863 [eDVBFrontend2] prepare_sat System 1 Freq 12581000 Pol 0 SR 22500000 INV 2 FEC 2 orbpos 1600 system 1 modulation 2 pilot 2, rolloff 0, is_id -1, pls_mode 1, pls_code 0, t2mi_plp_id -1 t2mi_pid 4096
< 592.4642> 11:21:09.3863 [eDVBFrontend2] tuning to 1211 mhz
< 592.4642> 11:21:09.3863 [eDVBChannel] OURSTATE: tuning
< 592.4642> 11:21:09.3864 [eDVBServicePMTHandler] tune failed.
< 592.4642> 11:21:09.3864 [eDVBServicePlay] DVB service failed to tune - error 1
< 592.4647> 11:21:09.3868 [eDVBServicePMTHandler] ignore sdt update data.... incorrect transponder tuned!!!
< 592.4647> 11:21:09.3868 [eDVBServicePMTHandler] incorrect namespace. expected: 6400000 current: ffffffff
< 592.4647> 11:21:09.3869 [eDVBServicePMTHandler] incorrect transport_stream_id. expected: 1 current: ffffffff
< 592.4647> 11:21:09.3869 [eDVBServicePMTHandler] incorrect original_network_id. expected: a9 current: ffffffff
< 592.4648> 11:21:09.3870 [eDVBFrontend2] set static current limiting
< 592.4649> 11:21:09.3870 [eDVBFrontend2] invalidate current switch params
< 592.4649> 11:21:09.3870 [eDVBFrontend2] set sequence pos 3
< 592.4649> 11:21:09.3871 [eDVBFrontend2] setVoltage 2
< 592.4774> 11:21:09.3996 [eDVBFrontend2] setTone 0
< 592.4894> 11:21:09.4115 [eDVBFrontend2] sleep 75ms
< 592.6355> 11:21:09.5576 [eDVBFrontend2] sendDiseqc: e0105a0d11(?)
< 592.6368> 11:21:09.5589 [eDVBFrontend2] sleep 150ms
< 592.7868> 11:21:09.7089 [eDVBFrontend2] setVoltage 1
< 592.8021> 11:21:09.7242 [eDVBFrontend2] update current switch params
< 592.8021> 11:21:09.7243 [eDVBFrontend2] startTuneTimeout 5000
< 592.8022> 11:21:09.7243 [eDVBFrontend2] setFrontend 1
< 592.8022> 11:21:09.7243 [eDVBFrontend2] setting frontend
< 592.8022> 11:21:09.7244 [eDVBFrontend2] fe event: status 0, inversion off, m_tuning 1
< 592.8023> 11:21:09.7244 [eDVBFrontend2] sleep 500ms
< 592.8689> 11:21:09.7910 [eDVBFrontend2] fe event: status 7, inversion off, m_tuning 2
< 592.9076> 11:21:09.8297 [eInputDeviceInit] 1 6c 1
< 592.9082> 11:21:09.8303 [InfoBarGenerics] KEY: 108 DOWN
< 593.0849> 11:21:10.0070 [eInputDeviceInit] 0 6c 1
< 593.0854> 11:21:10.0075 [InfoBarGenerics] KEY: 108 DOWN
< 593.0858> 11:21:10.0080 [eInputDeviceInit] 1 6c 1
< 593.0860> 11:21:10.0081 [InfoBarGenerics] KEY: 108 DOWN
< 593.1781> 11:21:10.1002 [eDVBFrontend0] fe event: status 1f, inversion off, m_tuning 0
< 593.3024> 11:21:10.2246 [eDVBFrontend2] set dynamic current limiting
< 593.3161> 11:21:10.2382 [eInputDeviceInit] 0 6c 1
< 593.3166> 11:21:10.2387 [InfoBarGenerics] KEY: 108 DOWN
< 593.5134> 11:21:10.4356 [eInputDeviceInit] 1 160 1
< 593.5140> 11:21:10.4361 [InfoBarGenerics] KEY: 352 OK
< 593.5145> 11:21:10.4366 [ActionMap] Keymap 'OkCancelActions' -> Action = 'ok'.
< 593.5351> 11:21:10.4572 [Skin] Processing screen 'EPGImportConfig', position=(0, 0), size=(1920 x 1080) for module 'EPGImportConfig'.
< 593.5483> 11:21:10.4704 [Skin] Processing screen 'SetupSummary', position=(0, 0), size=(480 x 320) for module 'SetupSummary'.
< 593.7452> 11:21:10.6673 [eInputDeviceInit] 0 160 1
< 593.7457> 11:21:10.6679 [InfoBarGenerics] KEY: 352 OK
< 597.4786> 11:21:14.4008 [eInputDeviceInit] 1 190 1
< 597.4792> 11:21:14.4014 [InfoBarGenerics] KEY: 400 YELLOW
< 597.7101> 11:21:14.6322 [eInputDeviceInit] 0 190 1
< 597.7106> 11:21:14.6328 [InfoBarGenerics] KEY: 400 YELLOW
< 597.7110> 11:21:14.6331 [ActionMap] Keymap 'ColorActions' -> Action = 'yellow'.
< 597.7358> 11:21:14.6579 [Skin] Processing screen 'MessageBox', position=(510, 340), size=(900 x 10) for module 'MessageBox'.
< 597.7413> 11:21:14.6634 [GUISkin] warning, skin is missing element icon in <class 'Screens.MessageBox.MessageBox'>(EPGImport
Import of epg data will start.
This may take a few minutes.
Is this ok?)< 597.7413> 11:21:14.6635
< 597.7414> 11:21:14.6635 [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
< 597.7416> 11:21:14.6637 [MessageBox] Timeout set to 15 seconds.
< 597.7426> 11:21:14.6647 [Skin] Processing screen 'MessageBox_summary' from list 'MessageBox_summary, SimpleSummary', position=(0, 0), size=(480 x 320) for module 'SimpleSummary'.
< 597.8022> 11:21:14.7243 [eDVBChannel] OURSTATE: failed, retune
< 597.8022> 11:21:14.7244 [eDVBFrontend2] tune
< 597.8023> 11:21:14.7244 [eDVBSatelliteEquipmentControl] [prepare] UnicableTuningWord 0xd11, guard_offset 0
< 597.8023> 11:21:14.7244 **** Tuning Unicable
< 597.8023> 11:21:14.7244 **** frequency_mhz: 12581
< 597.8023> 11:21:14.7244 **** lo_mhz: 11300
< 597.8023> 11:21:14.7244 **** ub_mhz: 1210
< 597.8023> 11:21:14.7244 **** T: 273
< 597.8023> 11:21:14.7244 **** ub: 0
< 597.8023> 11:21:14.7244 **** position: 0
< 597.8023> 11:21:14.7244 **** mode: 3
< 597.8023> 11:21:14.7244 **** bank: 3
< 597.8023> 11:21:14.7244 **** Unicable: e0 10 5a 0d 11
< 597.8023> 11:21:14.7245 **** Calculated tuningword: 0d11
< 597.8023> 11:21:14.7245 **** Stored tuningword: 0d11
< 597.8023> 11:21:14.7245 [eDVBSatelliteEquipmentControl] RotorCmd ffffffff, lastRotorCmd ffffffff
< 597.8024> 11:21:14.7245 [eDVBFrontend2] prepare_sat System 1 Freq 12581000 Pol 0 SR 22500000 INV 2 FEC 2 orbpos 1600 system 1 modulation 2 pilot 2, rolloff 0, is_id -1, pls_mode 1, pls_code 0, t2mi_plp_id -1 t2mi_pid 4096
< 597.8024> 11:21:14.7245 [eDVBFrontend2] tuning to 1211 mhz
< 597.8024> 11:21:14.7245 [eDVBChannel] OURSTATE: tuning
< 597.8024> 11:21:14.7245 [eDVBServicePMTHandler] tune failed.
< 597.8024> 11:21:14.7246 [eDVBServicePlay] DVB service failed to tune - error 1
< 597.8029> 11:21:14.7250 [eDVBServicePMTHandler] ignore sdt update data.... incorrect transponder tuned!!!
< 597.8029> 11:21:14.7250 [eDVBServicePMTHandler] incorrect namespace. expected: 6400000 current: ffffffff
< 597.8029> 11:21:14.7251 [eDVBServicePMTHandler] incorrect transport_stream_id. expected: 1 current: ffffffff
< 597.8029> 11:21:14.7251 [eDVBServicePMTHandler] incorrect original_network_id. expected: a9 current: ffffffff
< 597.8031> 11:21:14.7252 [eDVBFrontend2] set static current limiting
< 597.8031> 11:21:14.7252 [eDVBFrontend2] invalidate current switch params
< 597.8031> 11:21:14.7253 [eDVBFrontend2] set sequence pos 3
< 597.8032> 11:21:14.7253 [eDVBFrontend2] setVoltage 2
< 597.8158> 11:21:14.7379 [eDVBFrontend2] setTone 0
< 597.8275> 11:21:14.7497 [eDVBFrontend2] sleep 75ms
< 597.9737> 11:21:14.8959 [eDVBFrontend2] sendDiseqc: e0105a0d11(?)
< 597.9744> 11:21:14.8965 [eDVBFrontend2] sleep 150ms
< 598.0289> 11:21:14.9510 [eDVBFrontend0] fe event: status 1f, inversion off, m_tuning 0
< 598.1245> 11:21:15.0466 [eDVBFrontend2] setVoltage 1
< 598.1363> 11:21:15.0584 [eDVBFrontend2] update current switch params
< 598.1363> 11:21:15.0584 [eDVBFrontend2] startTuneTimeout 5000
< 598.1363> 11:21:15.0585 [eDVBFrontend2] setFrontend 1
< 598.1364> 11:21:15.0585 [eDVBFrontend2] setting frontend
< 598.1623> 11:21:15.0845 [eDVBFrontend2] fe event: status 0, inversion off, m_tuning 1
< 598.1624> 11:21:15.0845 [eDVBFrontend2] sleep 500ms
< 598.2201> 11:21:15.1423 [eDVBFrontend2] fe event: status 7, inversion off, m_tuning 2
< 598.6626> 11:21:15.5847 [eDVBFrontend2] set dynamic current limiting
< 599.0181> 11:21:15.9402 [eDVBFrontend0] fe event: status 1f, inversion off, m_tuning 0
< 599.6348> 11:21:16.5569 [eInputDeviceInit] 1 160 1
< 599.6354> 11:21:16.5575 [InfoBarGenerics] KEY: 352 OK
< 599.6358> 11:21:16.5579 [ActionMap] Keymap 'MsgBoxActions' -> Action = 'ok'.
< 599.6563> 11:21:16.5784 [eEPGCache] flushEPG 0
< 599.6593> 11:21:16.5815 [eEPGCache] start caching events(1604528476)
< 599.6594> 11:21:16.5815 [eDVBSectionReader] DMX_SET_FILTER pid=211
< 599.6597> 11:21:16.5818 [eDVBSectionReader] DMX_SET_FILTER pid=561
< 599.6599> 11:21:16.5820 [eDVBSectionReader] DMX_SET_FILTER pid=3842
< 599.6601> 11:21:16.5823 [eDVBSectionReader] DMX_SET_FILTER pid=3003
< 599.6604> 11:21:16.5825 [eDVBSectionReader] DMX_SET_FILTER pid=18
< 599.6609> 11:21:16.5830 [eDVBSectionReader] DMX_SET_FILTER pid=18
< 599.6615> 11:21:16.5836 [eDVBSectionReader] DMX_SET_FILTER pid=18
< 599.6623> 11:21:16.5845 [huffman] read.. '/usr/share/enigma2/otv_06400000_00a9_0009.dict'
< 599.6624> 11:21:16.5845 [eEPGCache] abort non avail OpenTV EIT reading
< 599.6624> 11:21:16.5845 [eEPGCache] start caching events(1604528476)
< 599.6646> 11:21:16.5867 Backtrace:
< 599.6648> 11:21:16.5869 /usr/bin/enigma2(_Z17handleFatalSignaliP9siginfo_tPv) [0x1929A8]
< 599.6649> 11:21:16.5870 /lib/libc.so.6(__default_rt_sa_restorer) [0xB6C8DE20]
< 599.6650> 11:21:16.5871 /usr/bin/enigma2(_ZN9eEPGCache12channel_data13cleanupOPENTVEv) [0x152758]
< 599.6651> 11:21:16.5873 /usr/bin/enigma2(_ZN9eEPGCache12channel_data8startEPGEv) [0x154F8C]
< 599.6653> 11:21:16.5874 /usr/bin/enigma2(_ZN9eEPGCache8flushEPGERK12uniqueEPGKey) [0x158240]
< 599.6654> 11:21:16.5875 /usr/bin/enigma2(n/a) [0xB59AC]
< 599.6654> 11:21:16.5875 -------FATAL SIGNAL (11)
dmesg
<6>[ 0.000000] Booting Linux on physical CPU 0x0
<5>[ 0.000000] Linux version 4.1.45-1.17 (oe-user@oe-host) (gcc version 8.2.0 (GCC) ) #1 SMP Wed Aug 14 09:06:07 UTC 2019
<6>[ 0.000000] CPU: ARMv7 Processor [420f1000] revision 0 (ARMv7), cr=30c5383d
<6>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine model: DUO4K
<6>[ 0.000000] moving dtb from 0x0000000047618000 to 0x000000004090d804
<6>[ 0.000000] bmem: Reserved 891 MiB at 0x0000000048400000
<6>[ 0.000000] bmem: Reserved 575 MiB at 0x00000000dc000000
<6>[ 0.000000] cma: Reserved 16 MiB at 0x00000000dac00000
<4>[ 0.000000] Forcing write-allocate cache policy for SMP
<6>[ 0.000000] Memory policy: Data cache writealloc
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] DMA zone: 1016 pages used for memmap
<7>[ 0.000000] DMA zone: 0 pages reserved
<7>[ 0.000000] DMA zone: 130048 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 394240 pages, LIFO batch:31
<6>[ 0.000000] psci: probing for conduit method from DT.
<6>[ 0.000000] psci: PSCIv0.2 detected in firmware.
<6>[ 0.000000] psci: Using standard PSCI v0.2 function IDs
<6>[ 0.000000] PERCPU: Embedded 12 pages/cpu @c7394000 s16844 r8192 d24116 u49152
<7>[ 0.000000] pcpu-alloc: s16844 r8192 d24116 u49152 alloc=12*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<6>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523272
<5>[ 0.000000] Kernel command line: libata.force=1:3.0G,2:3.0G,3:3.0G root=/dev/mmcblk0p9 rootfstype=ext4 rootflags=data=journal rootwait rw coherent_pool=2M vmalloc=500m bmem=891m@1156m bmem=575m@3520m
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] Memory: 550704K/2097152K available (6262K kernel code, 299K rwdata, 2152K rodata, 312K init, 202K bss, 1530064K reserved, 16384K cma-reserved, 442364K highmem)
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
<5>[ 0.000000] vmalloc : 0xe0000000 - 0xff000000 ( 496 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xdfc00000 ( 508 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc083fe00 (8416 kB)
<5>[ 0.000000] .init : 0xc0840000 - 0xc088e000 ( 312 kB)
<5>[ 0.000000] .data : 0xc088e000 - 0xc08d8d28 ( 300 kB)
<5>[ 0.000000] .bss : 0xc08db000 - 0xc090d804 ( 203 kB)
<6>[ 0.000000] Hierarchical RCU implementation.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe0002000, parent irq: 115)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe0008000, parent irq: 66)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe000a800, parent irq: 67)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe000c640, parent irq: 117)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe000e200, parent irq: 60)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe0010400, parent irq: 122)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe0012380, parent irq: 123)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe0014440, parent irq: 120)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe00163c0, parent irq: 121)
<6>[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xe0018000, parent irq: 126)
<6>[ 0.000000] Architected cp15 timer(s) running at 27.00MHz (phys).
<6>[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x63a1e71a3, max_idle_ns: 440795203123 ns
<6>[ 0.000003] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 4398046511093ns
<6>[ 0.000009] Switching to timer-based delay loop, resolution 37ns
<6>[ 0.000311] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=27000)
<6>[ 0.000319] pid_max: default: 32768 minimum: 301
<6>[ 0.000404] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 0.000407] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
<6>[ 0.000780] CPU: Testing write buffer coherency: ok
<6>[ 0.000981] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
<6>[ 0.001016] Setting up static identity map for 0x400084c0 - 0x40008518
<6>[ 0.002862] MCP: Enabling write pairing
<6>[ 0.014902] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
<6>[ 0.026789] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
<6>[ 0.038660] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
<6>[ 0.038682] Brought up 4 CPUs
<6>[ 0.038689] SMP: Total of 4 processors activated (216.00 BogoMIPS).
<6>[ 0.038693] CPU: All CPU(s) started in HYP mode.
<6>[ 0.038695] CPU: Virtualization extensions available.
<6>[ 0.038990] devtmpfs: initialized
<6>[ 0.046187] VFP support v0.3: implementor 42 architecture 3 part 10 variant 0 rev 0
<6>[ 0.046331] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
<6>[ 0.046347] futex hash table entries: 1024 (order: 4, 65536 bytes)
<6>[ 0.047594] NET: Registered protocol family 16
<6>[ 0.048544] DMA: preallocated 2048 KiB pool for atomic coherent allocations
<6>[ 0.053488] cpuidle: using governor ladder
<6>[ 0.059498] cpuidle: using governor menu
<6>[ 0.064457] No ATAGs?
<6>[ 0.064482] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.064486] hw-breakpoint: maximum watchpoint size is 8 bytes.
<6>[ 0.064731] Broadcom Brahma-B15 readahead cache at: 0xe02d8478
<6>[ 0.075468] brcmstb-gpio 840a500.gpio: Registered 5 banks (GPIO(s): 0-159)
<6>[ 0.075602] brcmstb-gpio 841a400.gpio: Registered 2 banks (GPIO(s): 160-223)
<5>[ 0.075975] SCSI subsystem initialized
<7>[ 0.076043] libata version 3.00 loaded.
<6>[ 0.076165] usbcore: registered new interface driver usbfs
<6>[ 0.076190] usbcore: registered new interface driver hub
<6>[ 0.076215] usbcore: registered new device driver usb
<6>[ 0.076258] Linux video capture interface: v2.00
<6>[ 0.076304] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.076306] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.076319] PTP clock support registered
<6>[ 0.076554] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.077093] Switched to clocksource arch_sys_counter
<5>[ 0.077249] FS-Cache: Loaded
<4>[ 0.078037] thermal thermal_zone0: failed to read out thermal zone (-22)
<6>[ 0.078110] NET: Registered protocol family 2
<6>[ 0.078395] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.078417] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.078448] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.078492] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.078502] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.078582] NET: Registered protocol family 1
<6>[ 0.078693] RPC: Registered named UNIX socket transport module.
<6>[ 0.078696] RPC: Registered udp transport module.
<6>[ 0.078698] RPC: Registered tcp transport module.
<6>[ 0.078700] RPC: Registered tcp NFSv4.1 backchannel transport module.
<7>[ 0.078709] PCI: CLS 0 bytes, default 64
<4>[ 0.079245] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
<6>[ 0.079263] hw perfevents: enabled with armv7_cortex_a15_on_a53 PMU driver, 7 counters available
<5>[ 0.080274] NFS: Registering the id_resolver key type
<5>[ 0.080289] Key type id_resolver registered
<5>[ 0.080292] Key type id_legacy registered
<6>[ 0.080301] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
<6>[ 0.080305] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
<5>[ 0.080400] FS-Cache: Netfs 'cifs' registered for caching
<5>[ 0.080433] Key type cifs.spnego registered
<6>[ 0.080506] fuse init (API version 7.23)
<6>[ 0.081066] bounce: pool size: 64 pages
<6>[ 0.081087] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
<6>[ 0.081101] io scheduler noop registered
<6>[ 0.081106] io scheduler deadline registered
<6>[ 0.081113] io scheduler cfq registered (default)
<6>[ 0.081273] brcm-gisb-arb 83fc000.gisb-arb: registered mem: e0306000, irqs: 260, 261
<6>[ 0.081564] brcmstb-usb-phy 8b38200.usb-phy: USB3.0 clock not found in Device Tree
<6>[ 0.081735] brcmstb-sata-phy 8b08100.sata_phy: registered 1 port(s)
<6>[ 0.082045] brcm-pci 8b10000.pcie: fixing incorrect interrupt-map in DT node
<6>[ 0.082083] PCI host bridge /pcie@8b10000 ranges:
<6>[ 0.082099] MEM 0x30000000..0x33ffffff -> 0xf0000000
<6>[ 0.082104] MEM 0x34000000..0x37ffffff -> 0xf4000000
<6>[ 0.182768] brcm-pci 8b10000.pcie: link down
<6>[ 0.182811] brcm-pci 8b20000.pcie: fixing incorrect interrupt-map in DT node
<6>[ 0.182841] PCI host bridge /pcie@8b20000 ranges:
<6>[ 0.182847] MEM 0x38000000..0x3bffffff -> 0xf8000000
<6>[ 0.182850] MEM 0x3c000000..0x3fefffff -> 0xfc000000
<6>[ 0.283447] brcm-pci 8b20000.pcie: link down
<6>[ 0.760613] brcmstb-dpfe 9932000.dpfe-cpu: registered.
<6>[ 1.341253] brcmstb-dpfe 9b32000.dpfe-cpu: registered.
<6>[ 1.341391] brcmstb_memc 9902000.memc-ddr: registered
<6>[ 1.341424] brcmstb_memc 9b02000.memc-ddr: registered
<6>[ 1.341592] brcm-waketimer 841a840.waketimer: registered, with irq 263
<6>[ 1.341725] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
<6>[ 1.342314] bcm7271-uart 840c000.serial: BAUD MUX clock not specified
<6>[ 1.342383] console [ttyS0] disabled
<6>[ 1.342398] 840c000.serial: ttyS0 at MMIO 0x840c000 (irq = 128, base_baud = 5062500) is a 16550A
<6>[ 2.163302] console [ttyS0] enabled
<6>[ 2.166907] bcm7271-uart 840d000.serial: BAUD MUX clock not specified
<6>[ 2.173414] 840d000.serial: ttyS1 at MMIO 0x840d000 (irq = 129, base_baud = 5062500) is a 16550A
<6>[ 2.182315] bcm7271-uart 840e000.serial: BAUD MUX clock not specified
<6>[ 2.188816] 840e000.serial: ttyS2 at MMIO 0x840e000 (irq = 130, base_baud = 5062500) is a 16550A
<6>[ 2.253575] iproc-rng200 8402000.rng: hwrng registered
<6>[ 2.260965] loop: module loaded
<6>[ 2.264590] brcmstb-sata-phy 8b08100.sata_phy: enabling SSC on port 0
<4>[ 2.271074] brcm-ahci 8b0a000.sata: masking port_map 0x1 -> 0x1
<6>[ 2.277018] brcm-ahci 8b0a000.sata: SSS flag set, parallel bus scan disabled
<6>[ 2.294106] brcm-ahci 8b0a000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
<6>[ 2.302995] brcm-ahci 8b0a000.sata: flags: 64bit ncq sntf stag pm clo pmp slum part
<6>[ 2.311400] scsi host0: brcm-ahci
<5>[ 2.314839] ata1: FORCE: PHY spd limit set to 3.0Gbps
<6>[ 2.319899] ata1: SATA max UDMA/133 mmio [mem 0x08b0a000-0x08b0c00f] port 0x100 irq 94
<6>[ 2.327829] brcm-ahci 8b0a000.sata: Broadcom AHCI SATA3 registered
<6>[ 2.334942] libphy: Fixed MDIO Bus: probed
<6>[ 2.341205] libphy: unimac MII bus: probed
<3>[ 2.349452] Broadcom BCM7278 8f805c0.mdio--1:05: failed to request GPHY clock
<6>[ 2.356602] unimac-mdio 8f805c0.mdio: Broadcom UniMAC MDIO bus at 0xe03d85c0
<6>[ 2.364228] brcm-systemport 9300000.ethernet: Broadcom SYSTEMPORT Litev 1.00 at 0xe03e0000 (irqs: 92, 0, TXQs: 16, RXQs: 1)
<6>[ 2.376108] xhci-brcm: xHCI BRCM driver
<6>[ 2.396514] xhci-brcm 8b39000.xhci_v2: xHCI Host Controller
<6>[ 2.402161] xhci-brcm 8b39000.xhci_v2: new USB bus registered, assigned bus number 1
<6>[ 2.410125] xhci-brcm 8b39000.xhci_v2: hcc params 0x0250f16d hci version 0x100 quirks 0x00010090
<6>[ 2.418932] xhci-brcm 8b39000.xhci_v2: irq 145, io mem 0x08b39000
<6>[ 2.425350] hub 1-0:1.0: USB hub found
<6>[ 2.429119] hub 1-0:1.0: 2 ports detected
<6>[ 2.433310] xhci-brcm 8b39000.xhci_v2: xHCI Host Controller
<6>[ 2.438948] xhci-brcm 8b39000.xhci_v2: new USB bus registered, assigned bus number 2
<6>[ 2.446729] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
<6>[ 2.455070] hub 2-0:1.0: USB hub found
<6>[ 2.458837] hub 2-0:1.0: 2 ports detected
<6>[ 2.463141] ehci-brcm: EHCI BRCM driver
<6>[ 2.467078] ohci-brcm: OHCI BRCM driver
<6>[ 2.471009] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[ 2.477552] ehci-pci: EHCI PCI platform driver
<6>[ 2.482048] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
<6>[ 2.488247] ohci-pci: OHCI PCI platform driver
<6>[ 2.492768] usbcore: registered new interface driver uas
<6>[ 2.498138] usbcore: registered new interface driver usb-storage
<6>[ 2.504221] mousedev: PS/2 mouse device common for all mice
<6>[ 2.509907] i2c /dev entries driver
<6>[ 2.513802] IR NEC protocol handler initialized
<6>[ 2.518344] IR RC5(x/sz) protocol handler initialized
<6>[ 2.523405] IR RC6 protocol handler initialized
<6>[ 2.527945] IR JVC protocol handler initialized
<6>[ 2.532484] IR Sony protocol handler initialized
<6>[ 2.537112] IR SANYO protocol handler initialized
<6>[ 2.541826] IR Sharp protocol handler initialized
<6>[ 2.546541] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 2.552385] IR XMP protocol handler initialized
<6>[ 2.557169] brcmstb_thermal 8151500.thermal: registered AVS TMON of-sensor driver
<6>[ 2.597136] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
<6>[ 2.617209] brcmstb-avs-cpufreq 8144000.avs-cpu-data-mem: registered
<6>[ 2.623794] sdhci: Secure Digital Host Controller Interface driver
<6>[ 2.629984] sdhci: Copyright(c) Pierre Ossman
<6>[ 2.634351] sdhci-pltfm: SDHCI platform and OF driver helper
<6>[ 2.640104] ata1.00: ATA-10: ST2000LM015-2E8174, 0001, max UDMA/133
<6>[ 2.641209] sdhci-brcmstb 84a0200.sdhci: No vmmc regulator found
<6>[ 2.641212] sdhci-brcmstb 84a0200.sdhci: No vqmmc regulator found
<6>[ 2.658503] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32)
<6>[ 2.671102] mmc0: SDHCI controller on 84a0200.sdhci [84a0200.sdhci] using ADMA 64-bit
<6>[ 2.681147] usbcore: registered new interface driver usbhid
<6>[ 2.686729] usbhid: USB HID core driver
<6>[ 2.692926] NET: Registered protocol family 17
<5>[ 2.697460] Distributed Switch Architecture driver version 0.1
<6>[ 2.703330] brcm-systemport 9300000.ethernet sys0: [0]: detected a Broadcom Starfighter 2 switch
<4>[ 2.712252] bcm_sf2_sw_setup: failed to request divider clock
<6>[ 2.718063] Starfighter 2 top: 4.08, core: 5.00 base: 0xe0400000, IRQs: 90, 91
<6>[ 2.725329] libphy: dsa slave smi: probed
<6>[ 2.755824] mmc0: MAN_BKOPS_EN bit is not set
<6>[ 2.766791] mmc0: new high speed MMC card at address 0001
<6>[ 2.772338] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
<6>[ 2.776914] mmcblk0boot0: mmc0:0001 4FTE4R partition 1 4.00 MiB
<6>[ 2.782879] mmcblk0boot1: mmc0:0001 4FTE4R partition 2 4.00 MiB
<6>[ 2.786097] 8f805c0.mdio--1:05: Broadcom BCM7278 PHY revision: 0x01, patch: 0
<6>[ 2.795982] mmcblk0rpmb: mmc0:0001 4FTE4R partition 3 512 KiB
<6>[ 2.803971] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
<6>[ 2.982045] ata1.00: configured for UDMA/133
<5>[ 2.986460] scsi 0:0:0:0: Direct-Access ATA ST2000LM015-2E81 0001 PQ: 0 ANSI: 5
<5>[ 2.994846] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
<5>[ 2.994897] sd 0:0:0:0: Attached scsi generic sg0 type 0
<5>[ 3.007923] sd 0:0:0:0: [sda] 4096-byte physical blocks
<5>[ 3.013244] sd 0:0:0:0: [sda] Write Protect is off
<7>[ 3.018045] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
<5>[ 3.018078] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
<6>[ 3.032102] dsa 8f00000.ethernet_switch eth0 (uninitialized): attached PHY at address 5 [Broadcom BCM7278]
<6>[ 3.042280] brcm-systemport 9300000.ethernet sys0: [1]: detected a Broadcom Starfighter 2 switch
<3>[ 3.051096] brcm-systemport 9300000.ethernet sys0: [1]: couldn't create dsa switch instance (error -22)
<6>[ 3.060670] 8021q: 802.1Q VLAN Support v1.8
<5>[ 3.064894] Key type dns_resolver registered
<5>[ 3.069282] Registering SWP/SWPB emulation handler
<6>[ 3.076386] ALSA device list:
<6>[ 3.079361] No soundcards found.
<6>[ 3.099040] sda: sda1
<5>[ 3.101873] sd 0:0:0:0: [sda] Attached SCSI disk
<4>[ 3.106865] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
<6>[ 3.123670] EXT4-fs (mmcblk0p9): mounted filesystem with journalled data mode. Opts: data=journal
<6>[ 3.132570] VFS: Mounted root (ext4 filesystem) on device 179:9.
<6>[ 3.142054] devtmpfs: mounted
<6>[ 3.145156] Freeing unused kernel memory: 312K
<6>[ 3.645328] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
<6>[ 3.768118] usb 1-2: new high-speed USB device number 2 using xhci-brcm
<6>[ 3.888842] hub 1-2:1.0: USB hub found
<6>[ 3.892673] hub 1-2:1.0: 4 ports detected
<6>[ 3.999115] usb 1-1: new high-speed USB device number 3 using xhci-brcm
<6>[ 4.121865] hub 1-1:1.0: USB hub found
<6>[ 4.125712] hub 1-1:1.0: 4 ports detected
<6>[ 4.329275] SGI XFS with security attributes, realtime, no debug enabled
<6>[ 4.545107] EXT4-fs (mmcblk0p9): re-mounted. Opts: nodelalloc,data=journal
<5>[ 4.785489] random: dd urandom read with 110 bits of entropy available
<6>[ 5.171114] usb 1-2.4: new full-speed USB device number 4 using xhci-brcm
<6>[ 5.340113] usb 1-2.3: new high-speed USB device number 5 using xhci-brcm
<6>[ 5.504115] usb 1-1.1: new high-speed USB device number 6 using xhci-brcm
<5>[ 5.560287] random: nonblocking pool is initialized
<6>[ 5.596158] usb-storage 1-1.1:1.0: USB Mass Storage device detected
<6>[ 5.602661] scsi host1: usb-storage 1-1.1:1.0
<6>[ 5.725330] EXT4-fs (mmcblk0p4): mounted filesystem without journal. Opts: (null)
<6>[ 5.758009] EXT4-fs (mmcblk0p5): mounted filesystem without journal. Opts: (null)
<5>[ 6.608381] scsi 1:0:0:0: Direct-Access USB2.0 FlashDisk 5.00 PQ: 0 ANSI: 2
<5>[ 6.616900] sd 1:0:0:0: Attached scsi generic sg1 type 0
<5>[ 6.616999] sd 1:0:0:0: [sdb] 1968128 512-byte logical blocks: (1.01 GB/961 MiB)
<5>[ 6.617173] sd 1:0:0:0: [sdb] Write Protect is off
<7>[ 6.617180] sd 1:0:0:0: [sdb] Mode Sense: 0b 00 00 08
<3>[ 6.617352] sd 1:0:0:0: [sdb] No Caching mode page found
<3>[ 6.617355] sd 1:0:0:0: [sdb] Assuming drive cache: write through
<6>[ 6.639331] sdb: sdb1
<5>[ 6.646689] sd 1:0:0:0: [sdb] Attached SCSI removable disk
<4>[ 6.727786] bcm_event: module license 'Proprietary' taints kernel.
<4>[ 6.734026] Disabling lock debugging due to kernel taint
<6>[ 6.775207] usb 1-2.3: USB disconnect, device number 5
<6>[ 6.966986] nexus.ko: virtual irq: enabled (267)
<6>[ 6.971702] nexus.ko: shared gpio banks: enabled
<6>[ 6.976547] usb 1-2.3: new high-speed USB device number 7 using xhci-brcm
<6>[ 7.078902] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
<6>[ 7.530125] brcm-systemport 9300000.ethernet sys0: Link is Up - 1Gbps/Full - flow control off
<4>[ 8.115723]
<4>[ 8.115723] Dongle Host Driver, version 1.363.110.16 (r620666)
<4>[ 8.115723] Compiled from
<4>[ 8.126007] Register interface [wlan3] MAC: 00:90:4c:11:22:33
<4>[ 8.126007]
<6>[ 8.288163] usbcore: registered new interface driver dbus_usbdev
<6>[ 13.912216] DVB: registering new adapter (_vuplus_duo4k_)
<4>[ 14.101231] bcm7444: hotplug_callback():
<4>[ 14.101231] Hotplug - status.connected 1:0:0
<4>[ 14.108235] bcm7444: hotplug_callback():
<4>[ 14.108235] Hotplug - connecting HDMI to display 0xe
<6>[ 14.411097] brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
<4>[ 14.463687] [MPVR]: >> misc_pvr_init
<4>[ 14.469799] [VID]: 6bcm7335_video_init
<4>[ 14.511625] [AUD]: 6bcm7335_audio_init
<4>[ 14.515849] [AUD]: >> bcm_audio_capture_init
<4>[ 14.524126] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 14.548630] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.556182] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 14.573604] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.581149] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 14.599430] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.606979] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 14.624386] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.631941] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 14.649629] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.657198] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 14.674612] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.682169] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 14.705219] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.712799] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1
<6>[ 14.731491] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.739104] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0
<6>[ 14.744990] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.752589] fe_cap.qam : 1, fe_cap.ofd : 1, fe_cap.satellite:0
<6>[ 14.758449] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
<4>[ 14.765997] -----------10 slot is empty ----------------
<4>[ 14.771329] -----------11 slot is empty ----------------
<4>[ 14.776657] -----------12 slot is empty ----------------
<4>[ 14.781982] -----------13 slot is empty ----------------
<4>[ 14.787309] -----------14 slot is empty ----------------
<4>[ 14.792636] -----------15 slot is empty ----------------
<4>[ 14.797970] bcm7444: bcm7335_frontend_init(): vtuner1 : 11
<4>[ 14.820073] BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
<4>[ 14.827564] BKNI_Malloc(linuxkernel) top users:
<4>[ 14.827564] blocks, bytes, filename:line
<4>[ 14.836551] 1015, 227108, BSEAV/lib/utils/balloc.c:31
<6>[ 14.868333] input: dreambox advanced remote control (native) as /devices/virtual/input/input0
<6>[ 14.880221] [TW8832]: registered
<6>[ 15.374135] [CI]: registered ci0
<6>[ 15.377575] [CI]: registered ci1
<6>[ 16.548285] [CI]: CI interface initialised
<6>[ 16.548285]
<6>[ 16.560132] [DFP]: registered dbox fp
<6>[ 16.566325] [SC]: registered sci0
<4>[ 16.697101] system_time_set wakeup mode get
<4>[ 16.761104] system_time_set wakeup mode get 0xc3
<4>[ 17.004455] BKNI_P_GetTrackAllocEntry_resize: resizing from 8704->14080
<4>[ 17.012983] BKNI_Malloc(linuxkernel) top users:
<4>[ 17.012983] blocks, bytes, filename:line
<4>[ 17.021978] 2408, 513784, BSEAV/lib/utils/balloc.c:31
<4>[ 17.263810] [VID]: VIDEO_SET_STREAMTYPE 0
<4>[ 17.267929] [VID]: VIDEO_SELECT_SOURCE 1 0
<4>[ 17.272220] [VID]: VIDEO_PLAY 1 2 0
<4>[ 17.321230] [VID]: VIDEO_CONTINUE 1 1
<4>[ 17.325093] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
<6>[ 17.349370] NET: Registered protocol family 10
<6>[ 17.609246] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
<4>[ 17.642411] [VID]: VIDEO_STOP 0 1
<4>[ 17.646842] [VID]: VIDEO_SELECT_SOURCE 0 0
<6>[ 19.039623] Bluetooth: Core ver 2.20
<6>[ 19.043268] NET: Registered protocol family 31
<6>[ 19.049156] Bluetooth: HCI device and connection manager initialized
<6>[ 19.055797] Bluetooth: HCI socket layer initialized
<6>[ 19.060700] Bluetooth: L2CAP socket layer initialized
<6>[ 19.067507] Bluetooth: SCO socket layer initialized
<6>[ 19.454114] dsa 8f00000.ethernet_switch eth0: Link is Down
<4>[ 19.783919] [VID]: VIDEO_SET_STREAMTYPE 0
<4>[ 19.788347] [VID]: VIDEO_SELECT_SOURCE 1 0
<4>[ 19.792652] [VID]: VIDEO_PLAY 1 2 0
<4>[ 19.841709] [VID]: VIDEO_CONTINUE 1 1
<4>[ 19.845690] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
<4>[ 20.162451] [VID]: VIDEO_STOP 0 1
<4>[ 20.166754] [VID]: VIDEO_SELECT_SOURCE 0 0
<6>[ 21.487874] dsa 8f00000.ethernet_switch eth0: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[ 21.496175] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
<3>[ 21.572408] [SC]: !!!unknown cmd 0x540b
<4>[ 32.711210] [AUD]: AUDIO_SET_MUTE 0
<4>[ 32.715102] [AUD]: AUDIO_SET_MIXER -1009607024
<4>[ 34.145335] [AUD]: AUDIO_SET_MIXER -1009607024
<4>[ 34.729665] FE tune fe_handle=c54d1400
<4>[ 35.086996] FE tune fe_handle=c4f08400
<4>[ 37.456548] FE tune fe_handle=c4f08400
<4>[ 39.710650] FE tune fe_handle=c4f08400
<4>[ 41.961870] FE tune fe_handle=c4f08400
<4>[ 44.278094] FE tune fe_handle=c4f08400
<4>[ 46.538165] FE tune fe_handle=c4f08400
<4>[ 48.780607] FE tune fe_handle=c4f08400
<4>[ 51.089376] FE tune fe_handle=c4f08400
<4>[ 53.307248] FE tune fe_handle=c4f08400
<4>[ 55.562214] FE tune fe_handle=c4f08400
<4>[ 57.777242] FE tune fe_handle=c4f08400
<4>[ 60.024255] FE tune fe_handle=c4f08400
<4>[ 62.361366] FE tune fe_handle=c4f08400
<4>[ 64.614183] FE tune fe_handle=c4f08400
<4>[ 66.856181] FE tune fe_handle=c4f08400
<4>[ 69.070188] FE tune fe_handle=c4f08400
<4>[ 71.307182] FE tune fe_handle=c4f08400
<4>[ 73.548208] FE tune fe_handle=c4f08400
<4>[ 75.890204] FE tune fe_handle=c4f08400
<4>[ 78.098267] FE tune fe_handle=c4f08400
<4>[ 80.359284] FE tune fe_handle=c4f08400
<4>[ 82.611254] FE tune fe_handle=c4f08400
<4>[ 84.859518] FE tune fe_handle=c4f08400
<4>[ 87.225490] FE tune fe_handle=c4f08400
<4>[ 89.470240] FE tune fe_handle=c4f08400
<4>[ 91.730231] FE tune fe_handle=c4f08400
<4>[ 93.987230] FE tune fe_handle=c4f08400
<4>[ 96.214297] FE tune fe_handle=c4f08400
<4>[ 98.525449] FE tune fe_handle=c4f08400
<4>[ 100.768307] FE tune fe_handle=c4f08400
<4>[ 103.026244] FE tune fe_handle=c4f08400
<4>[ 105.361453] FE tune fe_handle=c4f08400
<4>[ 107.625458] FE tune fe_handle=c4f08400
<4>[ 109.969859] FE tune fe_handle=c4f08400
<4>[ 112.218490] FE tune fe_handle=c4f08400
<4>[ 114.477383] FE tune fe_handle=c4f08400
<4>[ 116.698681] FE tune fe_handle=c4f08400
<4>[ 118.946278] FE tune fe_handle=c4f08400
<4>[ 121.205390] FE tune fe_handle=c4f08400
<4>[ 123.535213] FE tune fe_handle=c4f08400
<4>[ 125.796443] FE tune fe_handle=c4f08400
<4>[ 128.065568] FE tune fe_handle=c4f08400
<4>[ 130.340574] FE tune fe_handle=c4f08400
<4>[ 132.589238] FE tune fe_handle=c4f08400
<4>[ 134.907309] FE tune fe_handle=c4f08400
<4>[ 137.200210] FE tune fe_handle=c4f08400
<4>[ 139.466284] FE tune fe_handle=c4f08400
<4>[ 141.731316] FE tune fe_handle=c4f08400
<4>[ 143.964550] FE tune fe_handle=c4f08400
<4>[ 146.301460] FE tune fe_handle=c4f08400
<4>[ 148.568217] FE tune fe_handle=c4f08400
<4>[ 150.821226] FE tune fe_handle=c4f08400
<4>[ 153.077454] FE tune fe_handle=c4f08400
<4>[ 155.355534] FE tune fe_handle=c4f08400
<4>[ 157.613339] FE tune fe_handle=c4f08400
<4>[ 159.954363] FE tune fe_handle=c4f08400
<4>[ 162.236309] FE tune fe_handle=c4f08400
<4>[ 164.554268] FE tune fe_handle=c4f08400
<4>[ 166.814354] FE tune fe_handle=c4f08400
<4>[ 169.073362] FE tune fe_handle=c4f08400
<4>[ 171.397606] FE tune fe_handle=c4f08400
<4>[ 173.658350] FE tune fe_handle=c4f08400
<4>[ 175.913350] FE tune fe_handle=c4f08400
<4>[ 178.190226] FE tune fe_handle=c4f08400
<4>[ 180.438499] FE tune fe_handle=c4f08400
<4>[ 182.748244] FE tune fe_handle=c4f08400
<4>[ 185.019306] FE tune fe_handle=c4f08400
<4>[ 187.285478] FE tune fe_handle=c4f08400
<4>[ 189.553287] FE tune fe_handle=c4f08400
<4>[ 191.787356] FE tune fe_handle=c4f08400
<4>[ 194.128315] FE tune fe_handle=c4f08400
<4>[ 196.407249] FE tune fe_handle=c4f08400
<4>[ 198.687327] FE tune fe_handle=c4f08400
<4>[ 200.957351] FE tune fe_handle=c4f08400
<4>[ 203.174359] FE tune fe_handle=c4f08400
<4>[ 205.433519] FE tune fe_handle=c4f08400
<4>[ 207.773232] FE tune fe_handle=c4f08400
<4>[ 210.036735] FE tune fe_handle=c4f08400
<4>[ 212.299541] FE tune fe_handle=c4f08400
<4>[ 214.558686] FE tune fe_handle=c4f08400
<4>[ 216.823494] FE tune fe_handle=c4f08400
<4>[ 219.159485] FE tune fe_handle=c4f08400
<4>[ 221.428235] FE tune fe_handle=c4f08400
<4>[ 223.671336] FE tune fe_handle=c4f08400
<4>[ 226.025506] FE tune fe_handle=c4f08400
<4>[ 228.257379] FE tune fe_handle=c4f08400
<4>[ 230.577357] FE tune fe_handle=c4f08400
<4>[ 232.842404] FE tune fe_handle=c4f08400
<4>[ 235.096315] FE tune fe_handle=c4f08400
<4>[ 237.357265] FE tune fe_handle=c4f08400
<4>[ 239.598530] FE tune fe_handle=c4f08400
<4>[ 241.863802] FE tune fe_handle=c4f08400
<4>[ 244.150281] FE tune fe_handle=c4f08400
<4>[ 246.408363] FE tune fe_handle=c4f08400
<4>[ 248.670247] FE tune fe_handle=c4f08400
<4>[ 250.901545] FE tune fe_handle=c4f08400
<4>[ 253.154396] FE tune fe_handle=c4f08400
<4>[ 255.454322] FE tune fe_handle=c4f08400
<4>[ 257.718480] FE tune fe_handle=c4f08400
<4>[ 259.968312] FE tune fe_handle=c4f08400
<4>[ 262.252249] FE tune fe_handle=c4f08400
<4>[ 264.510299] FE tune fe_handle=c4f08400
<4>[ 266.856397] FE tune fe_handle=c4f08400
<4>[ 269.122544] FE tune fe_handle=c4f08400
<4>[ 271.363537] FE tune fe_handle=c4f08400
<4>[ 273.627310] FE tune fe_handle=c4f08400
<4>[ 275.872277] FE tune fe_handle=c4f08400
<4>[ 278.216269] FE tune fe_handle=c4f08400
<4>[ 280.472303] FE tune fe_handle=c4f08400
<4>[ 282.737266] FE tune fe_handle=c4f08400
<4>[ 285.083514] FE tune fe_handle=c4f08400
<4>[ 287.352280] FE tune fe_handle=c4f08400
<4>[ 289.622437] FE tune fe_handle=c4f08400
<4>[ 291.946323] FE tune fe_handle=c4f08400
<4>[ 294.221528] FE tune fe_handle=c4f08400
<4>[ 296.477225] FE tune fe_handle=c4f08400
<4>[ 298.711239] FE tune fe_handle=c4f08400
<4>[ 300.990249] FE tune fe_handle=c4f08400
<4>[ 303.323536] FE tune fe_handle=c4f08400
<4>[ 305.585733] FE tune fe_handle=c4f08400
<4>[ 307.850299] FE tune fe_handle=c4f08400
<4>[ 310.105642] FE tune fe_handle=c4f08400
<4>[ 312.372412] FE tune fe_handle=c4f08400
<4>[ 314.717368] FE tune fe_handle=c4f08400
<4>[ 316.980610] FE tune fe_handle=c4f08400
<4>[ 319.237257] FE tune fe_handle=c4f08400
<4>[ 321.498634] FE tune fe_handle=c4f08400
<4>[ 323.759501] FE tune fe_handle=c4f08400
<4>[ 326.066295] FE tune fe_handle=c4f08400
<4>[ 328.332400] FE tune fe_handle=c4f08400
<4>[ 330.602435] FE tune fe_handle=c4f08400
<4>[ 332.857252] FE tune fe_handle=c4f08400
<4>[ 335.103536] FE tune fe_handle=c4f08400
<4>[ 337.366246] FE tune fe_handle=c4f08400
<4>[ 339.686225] FE tune fe_handle=c4f08400
<4>[ 341.926272] FE tune fe_handle=c4f08400
<4>[ 344.262443] FE tune fe_handle=c4f08400
<4>[ 346.509285] FE tune fe_handle=c4f08400
<4>[ 348.777323] FE tune fe_handle=c4f08400
<4>[ 351.101565] FE tune fe_handle=c4f08400
<4>[ 353.368304] FE tune fe_handle=c4f08400
<4>[ 355.630270] FE tune fe_handle=c4f08400
<4>[ 357.870309] FE tune fe_handle=c4f08400
<4>[ 360.135508] FE tune fe_handle=c4f08400
<4>[ 362.388260] FE tune fe_handle=c4f08400
<4>[ 364.653337] FE tune fe_handle=c4f08400
<4>[ 366.881499] FE tune fe_handle=c4f08400
<4>[ 369.153362] FE tune fe_handle=c4f08400
<4>[ 371.412198] FE tune fe_handle=c4f08400
<4>[ 373.653205] FE tune fe_handle=c4f08400
<4>[ 375.986250] FE tune fe_handle=c4f08400
<4>[ 378.205267] FE tune fe_handle=c4f08400
<4>[ 380.448201] FE tune fe_handle=c4f08400
<4>[ 382.708200] FE tune fe_handle=c4f08400
<4>[ 384.941335] FE tune fe_handle=c4f08400
<4>[ 387.254197] FE tune fe_handle=c4f08400
<4>[ 389.500312] FE tune fe_handle=c4f08400
<4>[ 391.750259] FE tune fe_handle=c4f08400
<4>[ 393.957232] FE tune fe_handle=c4f08400
<4>[ 396.224295] FE tune fe_handle=c4f08400
<4>[ 398.571173] FE tune fe_handle=c4f08400
<4>[ 400.803338] FE tune fe_handle=c4f08400
<4>[ 403.045323] FE tune fe_handle=c4f08400
<4>[ 405.360340] FE tune fe_handle=c4f08400
<4>[ 407.612258] FE tune fe_handle=c4f08400
<4>[ 409.811221] FE tune fe_handle=c4f08400
<4>[ 412.126220] FE tune fe_handle=c4f08400
<4>[ 414.378235] FE tune fe_handle=c4f08400
<4>[ 416.610262] FE tune fe_handle=c4f08400
<4>[ 418.871197] FE tune fe_handle=c4f08400
<4>[ 421.129258] FE tune fe_handle=c4f08400
<4>[ 423.384758] FE tune fe_handle=c4f08400
<4>[ 425.688486] FE tune fe_handle=c4f08400
<4>[ 427.929181] FE tune fe_handle=c4f08400
<4>[ 430.179252] FE tune fe_handle=c4f08400
<4>[ 432.422281] FE tune fe_handle=c4f08400
<4>[ 434.628207] FE tune fe_handle=c4f08400
<4>[ 436.869204] FE tune fe_handle=c4f08400
<4>[ 439.189232] FE tune fe_handle=c4f08400
<4>[ 441.439288] FE tune fe_handle=c4f08400
<4>[ 443.648173] FE tune fe_handle=c4f08400
<4>[ 445.897175] FE tune fe_handle=c4f08400
<4>[ 448.141266] FE tune fe_handle=c4f08400
<4>[ 450.414264] FE tune fe_handle=c4f08400
<4>[ 452.660035] FE tune fe_handle=c4f08400
<4>[ 454.869194] FE tune fe_handle=c4f08400
<4>[ 457.114156] FE tune fe_handle=c4f08400
<4>[ 459.323268] FE tune fe_handle=c4f08400
<4>[ 461.684265] FE tune fe_handle=c4f08400
<4>[ 463.930180] FE tune fe_handle=c4f08400
<4>[ 466.264376] FE tune fe_handle=c4f08400
<4>[ 468.528232] FE tune fe_handle=c4f08400
<4>[ 470.771230] FE tune fe_handle=c4f08400
<4>[ 473.111735] FE tune fe_handle=c4f08400
<4>[ 475.342466] FE tune fe_handle=c4f08400
<4>[ 477.610817] FE tune fe_handle=c4f08400
<4>[ 479.874287] FE tune fe_handle=c4f08400
<4>[ 482.100498] FE tune fe_handle=c4f08400
<4>[ 484.357381] FE tune fe_handle=c4f08400
<4>[ 486.660583] FE tune fe_handle=c4f08400
<4>[ 488.937266] FE tune fe_handle=c4f08400
<4>[ 491.213416] FE tune fe_handle=c4f08400
<4>[ 493.444557] FE tune fe_handle=c4f08400
<4>[ 495.717432] FE tune fe_handle=c4f08400
<4>[ 498.037324] FE tune fe_handle=c4f08400
<4>[ 500.300497] FE tune fe_handle=c4f08400
<4>[ 502.554644] FE tune fe_handle=c4f08400
<4>[ 504.830244] FE tune fe_handle=c4f08400
<4>[ 507.100812] FE tune fe_handle=c4f08400
<4>[ 509.321556] FE tune fe_handle=c4f08400
<4>[ 511.577345] FE tune fe_handle=c4f08400
<4>[ 513.891237] FE tune fe_handle=c4f08400
<4>[ 516.153391] FE tune fe_handle=c4f08400
<4>[ 518.390252] FE tune fe_handle=c4f08400
<4>[ 520.670323] FE tune fe_handle=c4f08400
<4>[ 522.941728] FE tune fe_handle=c4f08400
<4>[ 525.266261] FE tune fe_handle=c4f08400
<4>[ 527.533848] FE tune fe_handle=c4f08400
<4>[ 529.813253] FE tune fe_handle=c4f08400
<4>[ 532.081455] FE tune fe_handle=c4f08400
<4>[ 534.319250] FE tune fe_handle=c4f08400
<4>[ 536.612213] FE tune fe_handle=c4f08400
<4>[ 538.930253] FE tune fe_handle=c4f08400
<4>[ 541.194578] FE tune fe_handle=c4f08400
<4>[ 543.456411] FE tune fe_handle=c4f08400
<4>[ 545.708369] FE tune fe_handle=c4f08400
<4>[ 547.992335] FE tune fe_handle=c4f08400
<4>[ 550.366242] FE tune fe_handle=c4f08400
<4>[ 552.622432] FE tune fe_handle=c4f08400
<4>[ 554.878514] FE tune fe_handle=c4f08400
<4>[ 557.137385] FE tune fe_handle=c4f08400
<4>[ 559.410455] FE tune fe_handle=c4f08400
<4>[ 561.656294] FE tune fe_handle=c4f08400
<4>[ 563.917408] FE tune fe_handle=c4f08400
<4>[ 566.237271] FE tune fe_handle=c4f08400
<4>[ 568.507255] FE tune fe_handle=c4f08400
<4>[ 570.768300] FE tune fe_handle=c4f08400
<4>[ 573.017421] FE tune fe_handle=c4f08400
<4>[ 575.286008] FE tune fe_handle=c4f08400
<4>[ 577.614366] FE tune fe_handle=c4f08400
<4>[ 579.874304] FE tune fe_handle=c4f08400
<4>[ 582.130194] FE tune fe_handle=c4f08400
<4>[ 584.422492] FE tune fe_handle=c4f08400
<4>[ 586.769296] FE tune fe_handle=c4f08400
<4>[ 589.157290] FE tune fe_handle=c4f08400
<4>[ 591.418614] FE tune fe_handle=c4f08400
<4>[ 593.655895] FE tune fe_handle=c4f08400
<4>[ 595.914456] FE tune fe_handle=c4f08400
<4>[ 598.170045] FE tune fe_handle=c4f08400
