[Request] Button for Graphics Multi EPG
Jotne
I do not like the long Blue Press for Graphics Mulit EPG.
Is it possible to get it direct on an empty key like "Home"?
Or remap Help button (that I do not need)
Home botton is not empty, but it is very usefull.
Without this function i cannot live.
In every menu where every you are home botton take you to the top of the menu. Very usefull :D
Yes i think it should be nice to have the possibilty to remap it.
As you say, Home is useful in every menu, but outside the Menus it is unassigned.
@Jotne, I presume you have the QuickButton plugin installed. Unzip the attached file, then copy the 2 files it contains to directory
/usr/lib/enigma2/python/Plugins/Extensions/Quickbutton
Restart Enigma2, then you will be able to program the Home key in the same way as the coloured keys (but without the long press).
Inside the BH Menus, Home will still work as before.
Hope you find this useful.
U can use long EPG button!
And if you have OFDb plugin,,,can be used from their!
Have Fun w/BH.
Long EPG button gives me the menu to select EPG and not the Grapics EPG directly that I do like.
I am not fan of long button press.
Cool, this works perfect
Thanks
Is it possible to get OK button to open channel list with Quickbutton?
I could not find any setting for it.
