Reset Password to Default
Search40
Hi, i have Vu Solo with Black Hole 2.1.4. trying to get in with FTP, but the person that has the box, it is not mine, has password but does not remember, i do not want to flash again, is there way to reset Password to Default, Thanks!!!!
I find way to get inside with network, not with ftp, could some one tell me where is the password located???, i mean like etc, usr and so on, so i can find out, Thanks!!!
It is strange yes but this is fault of linux i think, if you are Connected on the same router, using Windows 7, you go to Computer, Network, Vu Solo, Configuration Share, and you are In, myself, i have firewall on router, password on my box, openwebif protected, as before some one got in to my box, so i have high security now, thanks!!
That should not be possible on Linux.
I suspect you have a problem with the ftp application you are using (SSH?), or the box ftp service has not started.
Have you tried with telnet?
