Restart Problem
ertanp
I am using BH 1.7.4 and I am experiencing two problems:
1. After installing an addon or when an application restarts the ultimo, or restarts the gui, it gets stuck at the starting gui screen. I have to go into the shutdown menu and select restart for it to work. It was also like this in previous versions of BH. Trying to change to one of the parallel universes also gets stuck at restart.
2. The second one is related to TS panel. Going into satellites manager and trying to change something usually crashes the box and voids the satellites list.
Any help on solving these will be appreciated.
No ideas????
Can anybody tell me what command is called to restart the box after a plugin is installed? Maybe I can create a link to the correct command.
Yes, yesterday I installed 1.7.5 and didn't restore any personal backups, hoping it would be ok. But it was like as I said.
Test first clean image with no external addons and plugins
and without USB stick.
After add a USB stick and see if it causes problems.
Test if needed with another USB stick.
The image works without above-mentioned problems,
and for sure no support here for TS panel and similar .
" it gets stuck at the starting gui screen. I have to go into the shutdown menu and select restart for it to work. ."
Your statement is not clear : How U get stuck,,,...then U go to shutdown menu,,,!
:wallbash: I do not understand !!
There is some plugin (or the like),you are adding , that causing this conflect!
:no: The issue has Nothing to do with BH Image!
It may be hardware or A/V settings issues!
