route script to load at startup
snutteb
Hi i try to make a route script to load at startup.
Anybody that knows how to??
i used
/etc/init.d/local
put in
#!/bin/bash and tryed #!/bin/sh
/sbin/route add 95.143.192.62 reject
and
run "update-rc.d local defaults" in telnet
but the route command is not relooded after reboot
You can try to start your script from /etc/init.d/bootmisc.sh
add like this in bootmisc.sh
if [ -x /usr/bin/name ]; then
/usr/bin/name
fi
Of course if you make a mistake,
you can break the image.
/usr/bin/name
fi
thx but i dont really understand???
where do i put my list of route commands like
I think you have to make script with your command with name.sh
put script file in to /user/bin
chmod 755 script file
example :
script file with name route.sh you have to chmod 755
if [ -x /usr/bin/route.sh ]; then
/usr/bin/route.sh
fi
example :
/usr/bin/route.sh
fi
ok thx where in bootmisc.sh shall i put it??
hi again i dont get it start at reboot????
i wrote like this in bootmisc.sh
read TIMESTAMP < /etc/timestamp
if [ ${TIMESTAMP} -gt $SYSTEMDATE ]; then
date -u ${TIMESTAMP#????}${TIMESTAMP%????????}
test -x /etc/init.d/hwclock.sh && /etc/init.d/hwclock.sh stop
fi
fi
#Black Hole
if [ -e "/bin/bh_parallel_mount" ]; then
fi
/usr/sbin/crond -c /etc/bhcron/
[ -e "/usr/bin/.Bhautoswap" ] && /usr/bin/.Bhautoswap
# end: if [ -x /usr/bin/route.sh ]; then
/usr/bin/route.sh
fi
exit 0
is this right place in bootmisc??
and if i run /usr/bin/route.sh in telnet it run my commands in the route file.
I run my script from here
# Update /etc/motd.
if test "$EDITMOTD" != no
then
uname -a > /etc/motd.tmp
sed 1d /etc/motd >> /etc/motd.tmp
mv /etc/motd.tmp /etc/motd
fi
if [ -x /usr/bin/myscript ]; then
/usr/bin/myscript
fi
# This is as good a place as any for a sanity check
