Request rte-player
thijss
Any way to make this plug-in work on the black-hole
I tried it on image 1.7.9 but i crashes my Ultimo would be nice for the Irish users
It's created by RogerThis and working on some other iamges
I put it in /usr/lib/enigma2/python/Plugins/Extensions/ ,is this right or should i put it somewhere else?
I know RogerThis is still working on it ,but lots of people have it working.
He also said feel to free to work on it or share around.
posted my crash log
If someone knows what's wrong please let me know i could never get the 1channel plug-in to work maybe it's something in my set up.
Any input will be apreciated
posted my crash log
The problem is not related to 1channel plugin but rte plugin and the error reside into DNS resolution ... check with care about DNS settings. I suggest to use Google DNSs: 8.8.8.8 & 8.8.4.4 instead of the ones provided by your ISP.
thanks for reply could you explain more where to change the dns setting
i never got 1channel plugin to work might that fix it to (not on my box at the moment)
or could you fix the DNS resolution in the plug-in
Did as you suggested turned of my DHCP and changed the DNS to 8.8.8.8 and BINGO the RTE-Player is working,i also tried 1channel plugin after this wich never worked for me and working perfect now.
Since i have my Ultimo i could never connect to the Black-Hole server and no problems after DNS change thanks for the info Matey.
I suggest to apply DNS server settings into your router :)
