Request RTL2832 + R820T (tuner) support
tiger255
Hello,
is possible to have this deveice working and included in the next release of black hole. This device seems to have more sensivity than E4000-tuner and also can be used as websdr (will be BH the first websdr receiver? ;-))
I'm trying to compile by myself, but maybe other people own this device.
TY
tiger255
I mean I need just for DVT ...
Looking in google for "120903_RTL2832_2836_2840_LINUX%2Brc%2Bdab%2Bfm.rar " I found some source (dropbox), maybe this help someone.
angelofsky1980
BlackHole Driver Specialist
Hello,
TY
Look HERE how to post infos about your device.
Thanks
tiger255
Thanks
Sorry for late answer, I got some hard work ...
Linux version 3.1.1 (amedeo@localhost.localdomain) (gcc version 4.4.3 (GCC) ) #1 SMP Sat Jul 7 08:53:45 CEST 2012
Fetching vars from bootloader... found 11 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 pci=1 smp=1 moca=0 usb=1
Using 512 MB + 0 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 0002a044 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 10000000 @ 20000000 (usable)
bmem: adding 17 MB LINUX region at 6 MB (0x01139000@0x006c7000)
bmem: adding 232 MB RESERVED region at 24 MB (0x0e800000@0x01800000)
bmem: adding 256 MB LINUX region at 512 MB (0x10000000@0x20000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  Normal  0x00000000 -> 0x00030000
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
    0: 0x00000000 -> 0x00010000
    0: 0x00020000 -> 0x00030000
On node 0 totalpages: 131072
  Normal zone: 1536 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 129536 pages, LIFO batch:31
PERCPU: Embedded 7 pages/cpu @81407000 s4384 r8192 d16096 u32768
pcpu-alloc: s4384 r8192 d16096 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129536
Kernel command line: bmem=232M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
Memory: 275196k/524288k available (5436k kernel code, 249092k reserved, 1135k data, 244k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 404 MHz (202.497 MHz counter)
Calibrating delay loop... 403.45 BogoMIPS (lpj=201728)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
pci 0000:01:00.0: [14e4:8602] type 0 class 0x000101
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
pci 0000:01:00.0: reg 24: [mem 0x00000000-0x00000fff]
pci 0000:01:00.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
pci 0000:01:00.0: BAR 5: set to [mem 0x10510000-0x10510fff] (PCI address [0x10510000-0x10510fff])
pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
Registering unionfs 2.5.11 (for 3.1.10)
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 537
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
sata_brcmstb 0000:01:00.0: version 4.0
brcm-pm: enabling sata clocks
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
PCI: Setting latency timer of device 0000:01:00.0 to 64
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:02:be:f5)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ata1: SATA link down (SStatus 4 SControl 300)
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device  success with 0
blackhole initialised
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
  No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=15142200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=15142200
Block size=00020000, erase shift=17
NAND Config: Reg=15142200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=f7ff1010, cfg=15142200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0302 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 3.2 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan:  mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
usb 2-1: new high speed USB device number 2 using ehci-brcm
Bad block table Bbt0 found at page 0000ffc0, version 0x01 for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0x01 for chip on CS0
nand_read_bbt: Bad block at 0x007c0000
nand_read_bbt: Bad block at 0x06540000
nand_read_bbt: Bad block at 0x06ba0000
Creating 8 MTD partitions on "brcmnand.0":
0x000000000000-0x000007200000 : "rootfs"
0x000007200000-0x000007600000 : "kernel"
0x000007600000-0x000007a00000 : "boot"
0x000007a00000-0x000007c00000 : "splash"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size:  131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
ata2: SATA link down (SStatus 4 SControl 300)
UBI: max. sequence number:      1488
UBI: attached mtd0 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            114 MiB
UBI: number of good PEBs:        909
UBI: number of bad PEBs:        3
UBI: number of corrupted PEBs:  0
UBI: max. allowed volumes:      128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:    1
UBI: available PEBs:            0
UBI: total number of reserved PEBs: 909
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 12/1
UBI: image sequence number:  1362579657
UBI: background thread "ubi_bgt0d" started, PID 46
UBIFS: parse sync
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:  112373760 bytes (109740 KiB, 107 MiB, 885 LEBs)
UBIFS: journal size:      9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:      w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 244k freed
NET: Registered protocol family 10
rtw driver version=v3.4.2_3727.20120404
Build at: Jul  7 2012 09:06:32
usbcore: registered new interface driver rtl8192cu
procmk_init
dvb_bcm7413: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (vuuno)
enable MII = 0
Booted !
NEXUS_Frontend_GetUserParameters 0 0
bcm7413: hotplug_callback():
Hotplug - status.connected 0
[GPIO]Default
[GPIO]RST Default
[GPIO]fpga secu
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (Vuplus FE)...
bcm7413: bcm7335_frontend_init(): vtuner1 : 2
[MPVR]: >> misc_pvr_init
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
[CI]:0 1
[CI]: registered ci0 0
[CI]: registered ci1 0
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
udevd (104): /proc/104/oom_adj is deprecated, please use /proc/104/oom_score_adj instead.
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1  2 0
[VID]: VIDEO_CONTINUE 1  1
[VID]: VIDEO_CLEAR_BUFFER 1  1 0
[VID]: VIDEO_STOP 0  1
[VID]: VIDEO_SELECT_SOURCE 0
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
[LCD]: unknown cmd 0x1015
[CI]:ci_dev_open
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
eth0: no IPv6 routers present
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -839393808
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
FE tune
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: proc_get_ac3 0 audio_passthrough_spdif : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[VID]: VIDEO_FREEZE 1  0
[VID]: VIDEO_PLAY 1  2 2
[VID]: VIDEO_SLOWMOTION 0    1
[VID]: VIDEO_FAST_FORWARD 0    1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xe0db1424
[AUD]: setting mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_CONTINUE 1 0 audio pid_hndl : 0x0
[AUD]: AUDIO_CONTINUE:bcm7335->audio_pid_hndl is null 0 0
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xe0db14b4
!!!pes_cb idx<0
    Tainted: P
nfsd 100989 6 - Live 0xe12b4000
exportfs 3994 1 nfsd, Live 0xe128a000
ext2 57147 0 - Live 0xe1274000
fpga_directc 57585 0 - Live 0xe1249000 (P)
brcmfb 1127 2 - Live 0xe122a000
dvb_bcm7413 5052965 30 fpga_directc,brcmfb, Live 0xe0965000 (P)
procmk 1397 2 fpga_directc,dvb_bcm7413, Live 0xe03d1000
8192cu 559432 0 - Live 0xe032f000
ipv6 342641 10 - Live 0xe0209000
T:  Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
B:  Alloc=  0/900 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0001 Rev= 3.01
S:  Manufacturer=Linux 3.1.1 ohci_hcd
S:  Product=Broadcom STB OHCI
S:  SerialNumber=ohci_hcd
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=  2 Ivl=255ms
T:  Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev= 3.01
S:  Manufacturer=Linux 3.1.1 ehci_hcd
S:  Product=Broadcom STB EHCI
S:  SerialNumber=ehci_hcd
E:  Ad=81(I) Atr=03(Int.) MxPS=  4 Ivl=256ms
T:  Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=0bda ProdID=2838 Rev= 1.00
S:  Manufacturer=Realtek
S:  Product=RTL2838UHIDIR
S:  SerialNumber=00000013
C:* #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
NIM Socket 0:
        Type: DVB-S2
        Name: Vuplus DVB-S NIM
        Frontend_Device: 0
and also:
root@vuuno:~# /usr/bin/usbtuner -V
UsbTuner v0.3.11
hope this help
angelofsky1980
Your DVB USB device with the RTL2832+R280T tuners will be supported soon when LinuxTV team implements them.
I've read in their Mailing List that someone works on the tuner driver .... when this combination will be supported we will report here the status
taskent
Hi,
I have this usb dvb working in ET9000, you can see the logs:
DVB: registering new adapter (dvb0)
DVB: registering adapter 0 frontend 0 (DVB-S2)...
DVB: registering adapter 0 frontend 1 (DVB-S2)...
input: front panel as /devices/virtual/input/input2
dvb-usb: found a 'RTL2832U DVB-T USB DEVICE' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (RTL2832U DVB-T USB DEVICE)
DVB: registering adapter 1 frontend 0 (Realtek DVB-T RTL2832)...
dvb-usb: RTL2832U DVB-T USB DEVICE successfully initialized and connected.
usbcore: registered new interface driver dvb_usb_rtl2832u
root@et9x00:~# lsmod
Module                  Size  Used by
dvb_usb_rtl2832       426328  2
dvb_usb                18026  1 dvb_usb_rtl2832
ipv6                  351430  12
dvb                  5022440  31
modloader2             32629  1 dvb
modloader              22281  0
tpm                     6509  3 dvb,modloader2,modloader
The same usb dvb with VU+ UNO don't work:
RTL2832U usb_init_bulk_setting : USB2.0 HIGH SPEED (480Mb/s)
RTL2832U check_tuner_type : ERROR Unknown tuner on board...
dvb-usb: no frontend was attached by 'RTL2832U DVB-T USB DEVICE'
input: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.1/usb2/2-1/input/input1
dvb-usb: schedule remote query interval to 287 msecs.
root@vuuno:~# lsmod
Module                  Size  Used by
dvb_usb_rtl2832      391387  0
rt2800usb              13121  0
rt2800lib              43443  1 rt2800usb
rt2x00usb              10681  1 rt2800usb
rt2x00lib              40506  3 rt2800usb,rt2800lib,rt2x00usb
mac80211              208171  3 rt2800lib,rt2x00usb,rt2x00lib
ipv6                  346524  12
brcmfb                  1127  3
dvb_bcm7413          5059988  2 fpga_directc,brcmfb
I:* If#= 0 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=ff Prot=ff Driver=dvb_usb_rtl2832u
root@vuuno:~# cat /proc/bus/nim_sockets
NIM Socket 0:
        Type: DVB-S2
        Frontend_Device: 0
I hope you can use this info and if you need some test only have to tell me
Thanks
angelofsky1980
Hi,
Module                  Size  Used by
ipv6                  351430  12
dvb                  5022440  31
modloader              22281  0
root@vuuno:~# lsmod
Module                  Size  Used by
rt2800usb              13121  0
ipv6                  346524  12
brcmfb                  1127  3
NIM Socket 0:
        Type: DVB-S2
        Frontend_Device: 0
Thanks
Thanks for info but I've already said (and writed) that LinuxTV team is working to support the combination of Realtek RTL2832 and R280T tuner.
On BH we are already working to implement these new devices.
taskent
But in other receiver (Xtrend ET9000) works very fine.
The only diference is the kernel 3.6.0 vs 3.1.1, is not posible to adapt the patch for VU+?
angelofsky1980
I understand it's not clear what choice we have made into BH Team.
We have choosed to use LATEST drivers for DVB USB devices. More updated than other kernels or teams.
Actually into BH 2.x images there are drivers for DVB USB devices made for kernel 3.8.
This mean that latest development will be included into BH images when are avaiable and when we have made sufficient tests with device in our hands.
We monitor constantly the official (OFFICIAL) mailing list from LinuxTV about Patches, fixes and so on.
I know how that device works in another box brand: some teams have included these Patches in their kernel. Every team make their decisions.
Please STOP this kind of discussion / comparison with other box brands: they are OFF TOPIC and we are not interested about them.
taskent
I'm not comparing, sorry about that but I don't knew how BH work. I just try to help aporting logs from VU+ and other box that work with this usb
tango110
any news about the linuxTV Team driver support ?
Ruben
Hello, I spoiling my Freeview-usb, and I wonder if this already works in blackhole, as it is the only image I want and I would like to buy this usb-tdt. A greeting and thanks.
angelofsky1980
The R820T driver is included into BH 2.0.6 image. Try with it
Ruben
Thank you so much, and what I can buy without fear funciene not. I really appreciate it. A greeting
Ruben
Hello again angelofsky1980, I installed this usb-tdt and if it is recognized, but not working properly, go all pixelated channels. Is there any solution?. Thank you very much for everything. A greeting
angelofsky1980
Can you try to connect your USB DVB device to an external powered USB hub?
Can be useful also a "dmesg" output when you reboot your box
