S k i n F a c t o r y 9
Matrix10
SkinFactory 9 (NO PIG) and SkinFactory 9P (PIG)
As Skin Factory 8
but with a different OSD / Movie / DVD / MyTube Player
With some minor and major changes in coding and standard panels.
Matrix10’s Registered & Protected Graphic
Copyright:All Rights Reserved
Fingerprint:Show digital fingerprint
88ca7509fdc8edcf52f321371f4d2791aa51d96a21a3a62c601909edf49d8b1a
Title:SkinFactory 9P
Description:SkinFactory 9P (Skin with PIG)
MCN:C35R6-5F9NN-54VQT
12bbb4f20ce8879ae05301b2ef7830c89eb98e35c98ec2a00fa75b90acc8e17b
Title:SkinFactory 9
Description:SkinFactory 9 SKIN
MCN:C5274-B85G6-HCLBW
Nice improvment Prince MX10!
However, @Channel Selection, the epg info , is the same color as channel name {Syfy (Stargate SG-1)} it would be more visible and differentiable , if its in other color,,,may be yellow {Syfy (Stargate SG-1)} !
At the end its up2U , you are the master,,,,,:notworthy:!
My big problem is that I do not like yellow . pufff
I'd like to make ​​the rest black and white and perhaps somewhat blue.
except buttons :idea:
Ok fine, but the moving bar is blue...:confused:!
How about red color like the small bar between channel : number & name ....{Syfy (Stargate SG-1)}!
Do not know how the blue bar mix with red....:confused:!
The graphic of the skin in general is nice!
Im sorry I think that I would not change anything I not like .
In principle, I do not like colored colorful skins
but you can change for yourself ??
to add color you have to add this coding
colorServiceDescriptionSelected="#c9a100"
You can change color if you change color code c9a100
like this in skin section
<screen name="ChannelSelection"
<widget source="Title" render="Label" position="0,27" size="1280,40" zPosition="1" halign="center" font="Regular;30" foregroundColor="black" backgroundColor="#21e2e2e2" transparent="1"/>
<widget name="list" position="70,111" size="780,510" scrollbarMode="showOnDemand" foregroundColorServiceNotAvail="#666666"
colorServiceDescriptionSelected="#c9a100"serviceItemHeight="30" serviceNumberFont="Regular;22" serviceNameFont="Regular;24" serviceInfoFont="Regular;23" colorEventProgressbarBorderSelected="#ffffff" picServiceEventProgressbar="SkinFactory9P/pl.png" selectionPixmap="SkinFactory9P/menu/button780x30.png"
transparent="1"/>
Nop,,,,did not work for me,,,tried to edit the skin.xml and add the line in red ( put it in 2 place as showen).....:wacko::suda:!
Restart e2...no booting,,,STB hang,,,,had to deleted SF 9P...STB normal defult skin on.....;)!
Will have to read more about skin making and look for privet lessons , then sell skins for 10$ each......:lol: !
:thanks: MX10...it was a fun experience!
Rgdz & Gdnite
a911
Rgdz & Gdnite
a911
SF 9P only skin.xml file
But you have to look for color you like ,edit only color .Colors hex codes you can find on net
Thank U, Prince MX10, I never underestimate the hard works U do to pleaze us users around the world.
Personally appropriate you & the BH Team for all U have been doing in this excellent forum!
Keep it up guys U'r #1
:thanks:!
a911
BH Lover!
Look's very nice..;)
Compliment and bravo masters and keep going like this..;)
Rgs,
Daconi
