s/pdif audio
MarsalTito
Hi,
i am having some issues.
Today i get lg home theater with digital audio in. I have no luck connectiong vu+ solo to it via spdif using toslink cable.
can you point me do i need to set some settings in black hole image to make it work.
Vu+ solo
BH image 1.7.5
Thank you very much
Hi,
Vu+ solo
BH image 1.7.5
Thank you very much
You should disable "Downmix AC3" audio first.
The audio should transit via optical cable automatically ...
hi,
i found it and disable it. but no audio from vu solo.
i have tested home theatre by connecting it to TV digital out it is working, but not ztrue 5.1 sound
Davor
hi,
i have found it and disable it as you suggested. no audio.
i even try flashing older bh images and vix same result. no audio at spdif :(
hi,
Uhm .... what is your setup? What is connected your box with other multimedia systems you have ? (HT, TV...)
Hi,
clean BH 1.7.5 image.
TV is connected using hdmi. no connection to HT.
Currently i am using this to get any kind of surround sound:
Solo connected to TV using hdmi, from TV to HT toslink cable
Thank you,
Davor
OP: Sorry if i interfer with your thread, but i am considering to get a similar setup, and curious to hear you and others opinions about such setup. My plan is to connect a 5.1 speakerset (with amp) thru a s/pdif cable. I see you have some technical difficulties, so im paying attention to see the outcome, and when you (hopefully) get it to work, would you care to share your experiences with the setup? I am curious how many dvb-s/s2 channels (in general) that benefit from 5.1 sound, and if you get some surround value out of it. I cant really find many audio settings, so it is difficult to predict what options BH offers. Will it automatically mirror front speakers to rear, if you watch a normal "stereo" channel?
Please share your experiences -once you get it to work :)
