Hello every one ,
i want to setup my samba server (on vu+ duo) with user and password authentification , but i don't know how to do that .
can someone help me configuring my smb.conf ?
Thanks.
thank you a911 for your answer ,of course i googled "samba configuration" , the problem is that i cannot use some commands to set up samba like "smb passwd -a user".
ThanksI will look into VuPlus source where are the Samba utilities.
Stay tuned![]()
Thanks
thanks i will try and inform youYou can try to install this IPK and report if contains the samba utilities.
Thank you angelofsky1980 , it worked like a charm ,regards.You can try to install this IPK and report if contains the samba utilities.
What about new package of samba ?
I try to install samba and i get
ipkg install /tmp/samba_3.0.37-r0_mipsel.ipk
Installing samba (3.0.37-r0) to root...
Collected errors:
* Package samba md5sum mismatch. Either the opkg or the package index are corrupt. Try 'opkg update'.
* Cannot find package samba.
