funky2nite
guys I've had my sat aligned with motor using usals lat long etc.... the only thing was that the sat couldnt tune to 28.2E because I have a wooden frame, rather than drilling new holes to move everything to the left, I loosened the nuts holding the motor to the mast / pole and simply rotated the motor horizontally / to the left no up and down just a bit to the left so when it moves it can tune to 28.2 without hitting the wooden frame.
thing is now it lost every sat, I tried putting it exactly where it was because I marked on the mast where it was but nothing. it moves over satellites and gets high SNR and it keeps moving and stops on a 0 SNR position.
I can put many new sats to static position but with motor I still cannot learn where it should be installed looking at direction the motor, I read a lot and alot, there are some that say to point motor to true south..then what? I know the receiver has lat and long but it references to what to move to other transpoders? I aligned it on hotbird 13E but bam I change channel and the sat simply goes to other position and when I change channel back it doesnt come back to where I aligned it..
any help would b appreciated A LOT, I've installed lots of sat for family and friends but static.
