The VU+ Zero is a single tuner satellite receiver.
Are you using a USB terrestrial tuner, to receive terrestrial channels?
How have you got the satellite tuner configured?
Can you please provide more information.
I assume you only have a fixed satellite dish, on 28.2E.
First you need to set the tuner, to simple, single, 28.2E, which I assume you've already done, but check by going into Menu, Setup, Tuner Configuration.
NExt try manually scanning in some FTA, Free To Air, channels.
Go into Menu, Setup, Service Searching, Manual scan, and enter a few frequencies, from lyngsat:
I could be wrong here but are you expecting the Vu Zero to just magically open any Sky channels that require a valid subscription card? If so it just doesn't work like that....
