Satellites- problems locating
John Bailey
Hi,
I decided to update my list of Satellites on my Duo,using Satellites-XML.org, I am now having problems in that all the Satellite positions appear to be now slightly out and 'satfinder' does not locate the correct satellite. All satellites seem to have moved slightly.
My motorised dish is still set as before, and Ihave not adjusted any of the settings.
Hope someone can help.
Regards,
John
I'm no expert but I know my way around. Maybe you should copy another xml file in your enigma and then try, or maybe upload a new setting list in your receiver and I think that will solve your problem.
Hi messale,
I loaded the xml file by ftp/ect/tuxbox.
I will try another xml file to see if that makes a differewnce as you suggest.
I would be grateful if you could expand on your comment re 'Setting list'.........what is this and how do I upload it?
Regards,
John
You just take a look for it, there are people making these kind of lists and you just upload them with dreambox edit or VUCC.
