satellites.xml / satloader pugin question
LassuPC
Using Black Hole, Vu+ Zero 4K. In plugin list, if I select the satloader plugin, it seems nothing is happening. Or is so fast I can see anything. It's normal?
If I put a satellites.xml file containing my favorite satellites in etc\tuxbox folder after a while is updated and it contains all satellites including those "from the other side " of the Earth.
Is this updated by the satloder plugin, or by the system?
In the channel list, if I press the green button, getting the satellites list, I can see a phantom satellite at 21.5 East (Eutelsat 21B is also in list as a separate item at 21.6, and has only 4 TV channels), this phantom satellite has no name, and has a lost of TV channels, all greyed.
In satellites.xml there is no item at 21.5. What is wrong?
