Sattelites.xml
bjorntj
I see that the satellites.xml has changed in the 2.0.x version of BH, putting Thor on 0.9W instead of 0.8W.. Can I use an old satelittes.xml file (from BH 1.7.x) or is there an easy way to convert all my existing files from using 0.8W to 0.9W?
Regards,
BTJ
Regards,
BTJ
By using
satellites.xml generator.
@ http://satellites-xml.eu/
U can make your own file!
Satellites-xml.eu is indeed a invaluable resource but i prefer to streamline my satellites.xml files by removing the countless and often pointless feeds transponders.
You can generate a new satellites.xml file in the same way from http://satellites-xml.org/ that only contains actual active transponders, this not only reduces the size of the overall file but can drastically reduce scan times as the box would normally make a lengthy pause over dead or inactive transponders while trying to get a lock, with those transponders removed this is no longer the case.
