Saudia TV HD , nilesat or Badr
bady71
hello all ,
please , can someone help me
i cannot get the saudia tv hd on nilesat or Badr with my Vu Ultimo
when i tried with another receiver , the channels works
hope i can make the right tuner configuration
thanks to all
You need to check your signal quality levels, some receivers have a more sensitive tuner, than others, I've noticed it takes more signal quality, to lock, and scan in, weaker quality levels, on my VU+ Duo 2, than my other receivers, but once tuned in the VU+ performs equally as well as my other receivers.
If it is a signal quality issue we need your general location, and dish size.
my location is Dubai , my dish size is 120cm
the other channels are perfectly work with my Vu ultimo , just the frequencies of this channels cannot be reach
thx to you ,
Are you using a V-Box II, by any chance, or any other devices, which connect to your receiver?
You could also check if those frequencies are affected by a DECT telephone.
no other devices are connected to Vu+
when i transfer the channels with dreamboxEDIT , signal have 77% but no sound or picture
Try manually scanning in the transopnders.
I have found a Saudi TV 1 HD listed on 26E, 12149 H 27500 DVB-S2 8PSK 5/6, and on
Yahsat 1A 52.5E, 11747 H 27500 DVB-S2 QPSK 8/9
The Tuner configuration depends on your satellite set up, do you have a fixed dish, single LNB, pointing at 26E, motorized dish, multiple dishes, and LNB's, using a Diseqc switch?
i've one diseqc with 3 sat , 26e is in port 3
i capturing all frequencies in 26e , only this frequency not coming
Try running a cable directly from the LNB to your receiver then try scanning in those frequencies, removing the Diseqc switrch, from the setup, just to confirm that the Diseqc switch isn't causing the problem.
Just because it works with a different receiver doesn't mean that it's compatible with your VU+.
Only by trying everything, will you isolate the problem, including DECT telephone interference, as different receivers are more susceptible to interference.
still same problem ...
some channels not coming when i make an tuner automatic scanning , just when i do a blind scan plugin , they comes !!!!
you've idea ?!?!?
hi ,
still same problem
i changed lnb , i changed DiSEqC
i connect the lnb directly to receiver ,, not coming the mentioned channels
maybe the problem from receiver manufacturing
can someone give explication ,
hello all ,
thanks to all
Hello please remove lnb switch diseqc or change it
you've idea ?!?!?
You no try used setting made by vaniball or other setting created by developers
