As a complete novice, I have hit a wall....
I've just acquired a Vu+ Duo with VTi image, previously set up for someone else. I've connected a single coax to it which comes from a satellite which has two LNBs, switched. The dish is pointing at 16E and there is an offset LNB for Astra (28.2E). I've looped one tuner to the other.
When I started to scan I was offered both satellites, as expected. Also as expected, the receiver found hundreds of channels on Astra. But it found nothing at 16E, where I am hoping to get channels from ex-Yugoslavia. To give one example channel, websites list RTRS (Banja Luka) on Eutelsat 16A, encryption "clear" and frequency 11262H. It also shows up on Eutelsat W2, where encryption is "Videoguard" and the frequency is 11428V. The receiver tells me it is scanning Eutelsat W2.
I can't make the receiver scan Eutelsat W2, only 16A. But if I do a single-transponder scan I can specify either 11262H or 11428V and both seem to be accepted. The result is always the same - nil channels found.
Any advice would be much appreciated.
