Scanning for channels
Satlawman
Great work as always by this team..
Can I ask this
1 where will I find the pli skins that I can use eg LT6hd
2 why does the channel
List not show the new channels found and provider when I scan but only the channel list
Keep up the fantastic work
Can I ask this
1) - While changing from Matrix10 ( fullhd skins ) to Pli Skins, it´s my opinion, i think you are changing more for less, to avoid you some conflicts ( Ex: gsod ), use skins optimized to image, the others not supported here, use at your own risk.
2) - On channels list press BLUE - Favourites ( and see if you have new channels ), i think you´ll have the new channels added.
