Just tried it and it is scanning in as a Data channel.
Download dreamboxedit:
http://www.vuplus-community.net/board/threads/dreamboxedit.18975/
On your receiver go into your menu, setup, system, network, LAN, or WLAN, depending on your connection, to your router, click on Adapter Settings and make a note of your receivers IP Address, if you don't already know it.
Go to your PC, download, and install dreamboxedit.
On your PC Desktop set up a new folder and call it Settings, usuallyu just right click, New Folder.
Open it and click tools, options, in the IP Address box now type your receivers IP Address and click Save, you can also use the Test IP Connection, to make sure you have it right.
Once done go to File, Fast FTP Download.
Now click on the All Satellites heading and select Thor 5/6 (0.8W)
Now click on the Sym heading, short for Symbol Rate, S/R, and you should see 11472 V 7120, right click, on this, and change it to TV.
To make it easier to find, as it has no name, you can edit it, to name it, or transfer it to a Bouquet, for 0.8W, by dragging it across, or even make up a new bouquet, for 0.8W, called feeds, and place it in that.
Now click the Save icon, or File, Save.
Now go to File, and click FTP, and Send Files to Dreambox, followed by the Restart Enigma 2 option.
You should now find the channel, on your VU+.
