Select correct audio track?
robisoft
I have a Vu+ Duo2 running OpenATV. All my recordings seem to have the audio recorded with the voice assistance for the poorly sighted viewers. How do I turn this on/off please? Thanks for reading.
This forum mainly refers to Black Hole, and Open Black Hole images, but in these images you have to set your Audio preferences, to get rid of the audio sub track.
Thank you Mick12334 for your prompt response. Sorry if I posted in the wrong place - I just went for "Newbies Questions & Infos" - whoops! Perhaps I should give BH or OBH a go, then I'll know where to go for help. How do I choose which one?
Black Hole is based on the official image, and is slightly easier to set up, I use Open Black Hole, as it has KODI 17.6, which I use quite a lot, and has more options,
Since you use ATV i would recommend that you try the OBH Image and you can do it with OpenMultiboot first
so you dont have to flash your box :)
