selfsat H30D1 + rotor HH90
vdurieu
hello
I have a VU+ duo under BH, with a selfsat flat antenna H30D1 (pointed on astra)
I would like to add a rotor to get hotbird too. I see the HH90 rotor by selfsat too
1) can I connect directly the rotor to the LNB input port of the VU+ ? no additionnal positionner required ?
2) is it compatible with selfsat H30D1
2) does someone try this setup ? is it fine / fast ... ?
thanks
hello
thanks
1) if the rotor supports DisecQ 1.2 and/or USALS (this one very suggsted) you can connect directly the rotor to your box
2) I don't know
3) I've tried the traditional 65cm dish size with an HH360 ClarkeTech rotor and all works properly.
hello
selfsat H30D1 flat antenna + rotor HH90 are installed (vu+ duo blackhole). I get a better SNR on astra than with my 75 cm antenna
is there a tutorial on how to configure the positionner ?
thanks for help
