Armageddon
BH Lover
We know the problems and limitations of EPG
You can not load into memory EPG, which is more than 10MB
without the risk to crash image enigma.
Backup is intended for those cases where it still crash image/enigma
for some reason.Then you can continue to use the EPG from backup.
If you use a EPG which is on the network drive
It will slow down image and ZAP .
since in that case you read EPG through the network.
Skins with PIG using 1280x720 pixels full screen
sometimes with heavy and large graphics
which of course slows down Menu / panels and the ZAP.
Allright, thanks for the information MX, i´ll try to use an USB stick and use both swap (64Meg, is that apropriate?), Rytec EPG storage and EPG backup on it. I´ll provide further information regarding this in a few days when I´ve tested properly.
