This may or may not be completely the correct thread.
I have been having a problem for some time now with Eurosport 2 disappearing. I have tried on other forums to get a satisfactory solution but no luck so far. This was my post:
I have a Vu+Duo using Black Hole 1.7.9 and ***** 2.2.1. I have a canaldigitaal card and all the channels work well except for Eurosport 2(Astra 19.2). It can take up to 9 minutes before I get video and sound on this channel. I wonder if ***** 2.2.1 has a switching or loading problem, as Eurosport 2 from Canaldigitaal happens to have the lowest frequency of all the offered channels. All the other channels switch very fast, only this one does not.
I make my own bouquets and upload them from my PC to my box using DreamSet. I have tried refreshing all channels, but that did not help.
Any ***** experts out there who can shed a light on this problem?
Thanks in advance for any suggestions.
Additional info. At times I can get an EPG from Eurosport 2 and no picture or sound. At other times no EPG at all. Currently it has taken more than 30 minutes with no picture, after which I get fed up waiting and change channels!
From King of Sat for Eurosport 2 Germany: (19.2°E Astra 1KR 10920.75 H 63 Astra 1KR DVB-S QPSK 22000 7/8 BetaDigital, 35.5 Mbps NID:133 TID:15)
Since reading this thread I have checked my Satellites.xml file by comparing the one on my box with a newly generated one. The entry in question is:
“<transponder frequency="10921000" symbol_rate="22000000" polarization="0" fec_inner="5" system="0" modulation="1"/>”
which is the same in both files.
I notice that Eurosport 2 is the only one of my channels on the Astra 1KR satellite. All my other channels are on the 1M or 1L satellites. Could that have anything to do with it? Could it be that my LNB is just a bit off correct alignment? (I do not have the problem on my very old Challenger II STB)
Any help or comments would be appreciated!
