Hi
Is it possible to set where I want the recordings should be placed? .
OBH 4.3
Before all, make clear your intention. If you want
always choose where do you want to record or, instead, if you want the chance of choosing a different path for each recording.
In the first case (although I guess the real reason under this "strange" question...) I'd ask: why, on earth, having a HDD connected (that uses a fast SATA bus connection) and using a slow USB?
If the reason is to connect to a PC to play your files, there are two "philosophical" issues in your approach:
a) You can always transfer your recording by a simple software like Filezilla or simply by the operative system itself, connecting to your VU+ /media/hdd/movie folder.
b) Instead of using a slow USB connection, risking troubles with the recording, particularly under OBH is very easy to copy elsewhere your recording. Ever tried to press MENU after selecting a recording in your Rec List? Obviously, you need to MAP your USB device, as p.rodrigues said.
If, instead, you want to choose a different device each time (taken that what I wrote in a) and b) is again valid) you need to set this choice by a Timer, where you can choose whatever path you like.
