Setting Tuner DiseqC A/B
hall9000
Good Morning
Recentlyy during setting tuner I have noticed that sttellite 19,2° shows two possibilities :
19,2 E Ku-band and 19,2 E Ka-band
What's the difference?
Which variant do I have to choose from Italy?
Thanks
Hall
There are several different bands, for some satellites, the most common is the Ku band.
It's not your location, that matters, but your satellite set up, including LNB.
Generally I think you should just select the Ku band options.
