Hello everyone. I need some help in setting up my motor and make it working with my decoder. I have the motor aligned, infact when I use positioner setup and use the fine tune I manage to get it to 97-99% signal strength, however when I exit the menu and I zap back to channel hitting the yes button it goes to the previous position with 25% signal strength. I tried to search for an answer but have not found anything yet.
My tuner position is set to simple and Positioner, and gave my longitude and latitude coordinates. Is it possible to have the tuner set to diseqc 1.2 motor that uses the satellite.xml file? I previously had a dreambox and used to set the motor to diseqc 1.2 and find 1 satellite and save that position and the ret of the satellites where automatically updated.
I found out that you can choose diseqc 1.2 in the advanced motor setup and choosing LNB 1 but I am only getting one satellite.
Any suggestions or help is appreciated.
