Setting up motor
asif007
Hi everyone I tried few attempts on this open black hole 0.1 version it is very good on fixed satellite setting but I can't get it to work on my motorised 90cm dish I have quad lnb setup tuner A is simple tuner B is equal to A tuner C is advance lnb1 and tuner D is second cable but when I try to set the position the dish moves away even though I have set the stored position twice but when I do a simple mode setup it works fine but I can't move the dish I have no problem on normal black hole 2.1.6 which I am using now
