Setting up tuner
Hi, I have a duo 2 with latest BH and I might need help setting up my tuner.
This is actually a quite generic sat question, but I believe I might get help here :)
I have 2 lnb quattro going into a 9x8 multiswitch.
I have no disecq, so I configured on simple and toneburst with 19.2 and 13 SATs.
Is it right or I am completely off?
Sent from my Nexus 4 using Tapatalk
Actually my emp centauri multiswitch seems to want diseqc 2.0.
I chose simple but I am not sure about the 2 yes/no options at the bottom.
It should be easier when the board bug is fixed and we can post from a PC, so I could attach a screenshot if necessary :)
So set Diseqc 1.0
Eheh the question is a bit broader :)
I set simple configuration with diseqc a/b Astra and hotbird. It seems to work but I don't know the meaning of the last 2 options and cannot find a suitable explanation. So I would like confirmation that I set it right and I won't have surprises in particular conditions :)
