setting up twin tuner vu+
nitrousbhp
is it possible to use a static dish plus a motorised dish with a vu duo, if not what set up would i require to run 2 cables from the motorised dish..i.e. would a twin lnb do the trick...as this is my first twin tuner, i still have a static dish
(not used at the moment)......... plus a motorised dish which was used with my previous receiver..nitrous
Two tuners are indipendent.
The most important thing is to have the two coax cables (one from fixed dish and one from motorized dish) near your box.
Configure the two tuners indipendently.
