Is there an easy way to get settings from one Vu+ box to another different Vu+ box ?
Is the "BH personal backup" file a unified file, that can be used between all/some Vu+ boxes ?
Is the "Software Management" "Backup System settings" backup-files unified files, that can be used between all/some Vu+ boxes ?
I am about to setup a new Vu+ duo2, and (if possible) i want to transfer the settings from a Vu+ solo2.
Or should i just setup the new Vu+ duo2 from scratch ?
Best regards
Best regards
