setup from Duo to Duo2
bigkenny
Hi.
My VU+ Duo (legit one) has gone faulty (3.5yrs old) so I`ve bought a new Duo2 (legit) it arrives this monday. Is there anything major in the setup that I would need to know from a Duo. I have saved all my sat channels etc using VU+ Control Centre so have all my settings saved. When I get my new Duo2 and flash it all back up with BH and update it all. If I then load the saved info from my old Duo (using VU+ Control Centre) Is that it, will it be all set up and ready to go. I`ve never used a Duo2 so dont know what the menu etc is like is it the same as the old Duo??
Hi.
If you use BH also on your new Duo2, menu items are always the same and you should restore your settings without problems.
OK thanks for the info. I was hoping it would be as you say as it would be a pain redoing it alll again. On another not my orginal Duo seems to be OK now so I will have another machine (better one to play with ;-) I will move the Orginal Duo to my bedroom so its not to bad. Thank you
