Sharing is not working
gabijgg
Hi guys! This morning I have installed the new 2.1.5. black hole image on my device. The matter is that I have tried to configure my shared folder on my pc in the same way that always but is not working. My shared folder is called movies so in the window I have put /movies. Is in the same way or the path have changed with the new version?
Is not good /movies.
movie ???
example :
You have on your PC folder VU with subfolder movie /vu/movie
you have to share /vu folder .Recording goes to movie
But you can use NetworkBrowser (in Network Configuration) to mount any folder on your PC but with share rights.
But you have to put in System>>Recording paths
Path for your recordings.
