ShootYourScreen
komodo
How can you delete screenshot taken by RC as I only succeeded in deleting screenshots by FTP program.
Yes, i think it's the only one solution. There is no option to delete screenshots from the menu, so you should delete shots by your self.
This script will delete the folder screenshots from /tmp, /media/hdd and /media/usb.
You can adjust it for your own needs :)
Unzip it and place Remove-screenshots.sh in /usr/script
Set rights to 755 and you`ll find it with the green --> blue button on the remote control.
grt.
  • Remove-screenshots.zip
x-xxxA
grt.
Done on Solo2 and works fine. Thanks to all for providing this plugin. Now it is easy to ScreenShot , view and delete by RC only.
>>Artorius<<
>>English Admin<<
I have repacked the file and added the script by Past2Present
  • enigma2-plugin-extensions-shootyourscreen_0.2_all.ipk
komodo
Hi, added all paths from the plugin to delete list, and added machine name to the end message.
Maybe you cuold add this to the package, but it's up to you :)
