Request Shortcut to timer listings
cdnj
Dear all,
I am fairly new to using these services but am finding it easier and easier each day.
I am after a little help though, if at all possible?
Using the latest blackhole image on a VU+ Duo.
You have a button on the remote that will take you straight to your recorded items for quick viewing but is there a way to have a button on the remote that will take you straight to your timer listings?
Up to now I have to press menu, all the way down to timers and there they are..
Just one click on the remote would be so much easier, if this is possible?
Thanks for any help anyone could give?
Timers direct access should be possible mapping a remote button by means of the Multi Quickbutton plugin.
