Shoutcast Radio
jrbmw
Shoutast radio not working for me for a while.The app opens but wont play any channels. Anyone else got this problem.Running latest bh on vuduo2.The app works ok on obh.
Regards
Regards
Where did you downloaded the plugin ??
Orginally from th bh feeds.But when it stopped working and I couldnt find it on the bh feeds I used the open bh version. Which worked the stopped.
Yes it did . Then after an image update the app opens but the stations dont play.
I am not sure of that
whether after Pli plugin update no longer works and not image update ???
I have old BH version and is working
but problem is small panel coded for SD skin formats
And perhaps not working as PLI version that you try
because it is not Complementary to VU + coding.
and this plugin is no longer supported by the author.
OLD BH version
after install Replace plugin.py
Thanks Matrix10
SHOUTcast radio for Black Hole image
Ok I think i have fix OBH version for Black Hole ( I have test only on Ultimo 4K)
(also changed font size)
test pls .
If it works well I'll put on the server
One version for HD boxes and one for 4K boxes
