Shut down / restart not working?
houge
Hello.
Thanks for reading my post.
Am i the only one having problems with shut down or restart of the box?
Every time i try to shut down or restart, it never does that.
I just get a screen info saying the box is restarting or shutting down, but then nothing else happens.
FW 2.1.4
Build 2014-12-16-meo-exp
Kernel 3.13.5
Regards
Houge
Hi.
I tried to flash the box with the new Black Hole Xbmc beta 2, and now it seems to work.
Regards
Houge
Well i guess it didn't.
After i have scanned the 5 LNBs, i again can´t restart or shut down the box.
Could it be something in the restart/shut down process, where it saves the current settings, but "hangs"?.
Regards
Houge.
2.1.5 fixed the shut down and restart problem, thanks!
I then got another problem with share and netdrive, will do a new post for that.
