Sid not found in Pat
Joe..
Hi does anyone know how to overcome this, I am using blackhole on vu solo2, I added some channels on 13e Hotbird and came across RAI 2 HD & RAI 3 HD. So I added them, but I cant open them it says everytime I select the channels it says Sid not found in Pat. So I tried to add the same channels in 19.2e and I didn't find them there.. Anyone ??
Re-scan HB 13E.
If I Re-scan HB13e will it duplicate all my other stored 13e channels, I done a blind scan once already?? scared to do it it again because everything will duplicate?
Thanks
I have Blind scanned a few days ago, so they must be correct ??
As until yesterday night I was perfectly watching those channels, I think that they are currently transmitted with the settings as on kingofsat's.
Probably blind scan failed for those channels, or you did it before September 18th (when the old RAI2 HD & RAI3 HD were removed from transponder 11662).
BTW remember that RAI1HD, RAI2HD and RAI3HD are constantly encrypted channels, you need a valid Tivusat subscription to be able to watch them.
Thanks Eragon, I have a tivusat subscription, is there a way to just have a group of Tivusat channels ? my channels are split as NEW, Service Provider & Satelite ??
If you want to create groups of favorite channels you have many options available, working on your PC or directly on the box with the help of some autobouquet maker plugin.
I personally prefer to manually create all my favorite bouquets.
I keep getting this each morning. BH 2.1.1 clean install. I have the EPG updating at 4am automatically.
I did an automatic rescan of all channels but still does it.
I leavie it in standby overnight, in the morning the box display says DVB Service, I switch on the the VU+ and TV is blank.
I then go to standby again, then turn it on and it shows the SIS message counting down. Screen goes blank and I can then use the box as normal.
Not a terrible thing to live with but what do I need st set/reset to stop this. On Astra satellite.
For those who have the same problem I will at least try to help you in the future as nobody else seems to know what this is.
I loaded the sat info ok, reloading it made no difference.
I am using openepg from skyuk source and had it set to reload at 4am and 7am, with this setting I get the SID not found message.
I changed this to 12am (noon) and seems ok now, I will try moving it to a lesser time, maybe 8am and experiment a bit.
Basically seems to get rid of the message if you play around with when openepg refreshes.
Hi I had this problem after i returned my Vu solo 2 box to be fixed( it failed to do an update and i switched the box off and then it would'nt reboot) when i got it back it updates at 10am and then it says DVB Service on the box i really like to know if you sorted yours out i'm scared to mess about as the box took 10 days to be fixed last time there a lot to these boxes and i feel i could mess it ip and be even worse pff
I have VU+ Duo2, single DVB-S tuner. I did the following:
- clean BH 2.1.4
- scan satellite 5W (automatic scan)
- found all services, incl. France 2, France 3, both FTA
- when I want to zap channels France 2, France 3, both FTA, I see message "SID not found in PAT", and no picture
- I flashed VTi 8.0.0 to my Duo2, and did the same. It works.
So, I report bug in BH 2.1.4 on Duo2 (original).
- clean BH 2.1.4
No bug....Mine works fine on these channels..
- clean BH 2.1.4
