signal dropping
asif007
hi all I have a problem with my signal dropping on my vu duo2 meaning it is showing 10% or 15% and I don't get to see anything until I turn the box off leave it few min then boot it up again and it shoots up to 80-90% depending on the channel I am using open black hole image but I had this problem with any black hole image I used in the past now it started to happen more frequent any suggestions please share thank you
You need to check if the problem is with your receiver, dish, LNB, or cable.
One easy way. to check your receiver, is to try it on somebody elses dish and see if the receiver works normally.
If it does then check that your dish is still aligned, and fixed correctly, although your description, of the problem, tends to make me think the problem is either your receiver, or LNB.
If the receiver works correctly, on another dish/LNB, then i'd check the cable, for any signs of water ingress, or damage, check the connections are tight, and correctly made, then finally try replacing the LNB, even if you borrow one, to use as a test.
