Simple question regarding Front Display
Sontawila
Hi all,
I have a Vu+ Duo2 and I only want to be able to use the front display to mirror whatever is being played by the receiver and be able to turn it on/off using the remote (default = off).
I have LCD4Linux installed but I have no idea how to configure it to do the above.
Thanks very much...
Thank you Eragon. I have found the option you mentioned and I turned on but still I have nothing on the LCD and the option now disappeared. I'm using Vox and LCD4Linux came within the image, is there a way to reset all settings?
I know the screen is working since it display the Vu log each time I restart the system.
