skin colors
amine2010
Hi All,
all the skins are beautifull but all based on black and white and it is not easy sometims to make difference between columns. so i am not a professional but i need help.
i need to change the color of the channel list so it will be easy for eyes: channel name with a color and program with other color and epg with another color.
thank you
Hi All,
thank you
You don´t have any need to modify @Matrix10 work, without his consentiment.
Why don´t you increase the size font of Channel Name and decrease the font size of the info.
You can do it by pressing the Menu button, when the ChannelList is open.
Another try you can do is configuring the channel list like I did (see the picture attached).
This means enabling, in the channel list configuration, the option called "Show column" not as "disabled" but deciding a value in width according to your taste. For instance, I set 325 pixels.
This width is referred to the channel name column, which won't be variable but fixed. At its right you'll have the current event, this way.
I also don't like, as you, the current programme name just following the channel name.
But, talking about EPG, you'll probably consider fundamental the MultiGraphicEPG, although it has a different aim.
Ale
You can resize the font size from info for MultiEpg Panel. ( reduce the font, otherwise it looks ugly ) :)
Press the MENU ... and resize it also!
:) Yes I know, it was just to show the MultiGraphicEPG mode, because many users don't even know it exists...
I chose this font size because I prefer to have many channels per page and many events.
But I know I can change it: I actually love the freedom of configuring many sections of the GUI that OBH offers! So I did many adjustments to the GUI.
