Skin = dreamTV-HD make crash when I try change skin.
Only solution - flashing backup...
Wrong: only solution is using “certified” OBH skins or ask the skin’s author to fix it.Skin = dreamTV-HD make crash when I try change skin.
Is on the list under plugin-skin.
