Skin Factory 2
Matrix10
Skin Factory 2
Skin Factory 2 is update for Skin Factory 1
New design and change small size for Easy OSD, Moviebar, MyTube, DVDplayers.
What makes this skin even more attractive .
aotta
Thank you for this update!
I like this skin very much, and it look similar to the "Concinnity", one of my favourite and one of the reason of using other image than BH in tha past.....
I'll try it as soon as i return home!
Matrix10
Look similar but not the same.
"Concinnity" is modification skin from Markus.K DVB forum.
And this skin have not the same graphic and coding.
Rgd MX
aotta
Rgd MX
I agree it's not the same: it's much better!!!! :) I'm testing it and it seems fantastic!
Thank you and Merry Xmas!
