Skin for BlackHole-2.1.7-vuuno
forzajuve
Hello
I tried to download a skin for my BlackHole-2.1.7-vuuno image, but I didn't find any one on the Black Hole image server (skins)
Is it possible to give the skin file in order to install it manually ?
Why the skins for the old version of BH have disappeared ?
PS: I can't install a new BH image because I don't have enough space after installation, that's why I still on 2.1.7
bogdanm
Moderator
This skin is fixed to last version image.
I think you mast be look to old post or maybe someone have he on his box.
Why you no used OBh image in flash and last Bh or OBh in moltiboot
forzajuve
Is there any one still having the old versions for the skins (2.x.x) ?
When I take a look into the Black Hole image server (skins), I only find those for 3.0.x
Why the team has dropped the old one ?
There are several reason for not having old skin in the image feed.
1. Its old and no longer compatible with any Vu+ STB
2. Installing old skin might chrash your STB if you dont install equal old plugins.
4. Now days 99% of the STB running that old image are Clones and for them there are Zero support.
Do as Bogdanm advice you. Download and flash your STB with OpenBlackhole
and if you still want to run Blackhole image then take advantage of the Multiboot plugin
and install latest BH Image. And for that image you find DarkSky as both HD and FHD :)
But most important you get a modern today image that brings new life into your Vu+
Matrix10
Again
Im sorry,
We can not provide support for old and new images.
That would be hundreds of skins on the server and in the download lists.
You ca use Open Black Hole which is smaller for flash.
