Skylink issues
pmisun
Hello, recently Ive upgraded VU+ ultimo with Newest blackhole 3...3 C.
Issue is that with skylink (M7 or newer one coding readers - multiple cards tried) the cards are not reading properly the signal, at background, there will hangout the last non-coded pic, and the coded program flicks in the loop with bricks.
Could you recommend me some stream? The signal is great, (56%+ signal strenght with dual astras / 92%+ transmission), all has been tested. Dont want to switch back to VTI cause of media centre Kodi chains.
Thanks in advance for suggestions,
br
Peter M.
