skywalker-1
Need2learn
Hello anyone connected a skywalker-1 with your Vu 4k box? I keep getting green screen just wanted to know a solution to fix it..
Ok I installed the debug file but after install it I could not generate the debug_dvb.txt and debug_wifi.txt files?
If you have installed correctly the package with two debug scripts, you can find them (and can execute!) from Green -> Blue panel
Looks like the satfinder plugin has issues, or the card is not being correctly identified?
Surprised to see anyone using that dvb-s only card on a Solo 4K receiver.
Screen <class 'Plugins.SystemPlugins.Satfinder.plugin.Satfinder'>((10,), {}): <type 'exceptions.AttributeError'>
File "/usr/lib/enigma2/python/mytest.py", line 239, in create
return screen(self, *arguments, **kwargs)
File "/usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/plugin.py", line 50, in __init__
self.tuner = Tuner(self.frontend)
AttributeError: 'Satfinder' object has no attribute 'frontend'
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
res = self.actions[action]()
File "/usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/plugin.py", line 250, in okbuttonClick
self.session.open(Satfinder, selection)
File "/usr/lib/enigma2/python/mytest.py", line 313, in open
dlg.isTmp = True
AttributeError: 'NoneType' object has no attribute 'isTmp'
So this is what I did a factory default and reloaded BH 3.02 F and it did the same thing then I try loading BH 3.02 E same thing, So what do you suggest I do to fix this problem, in order to use my genpix Skywalker-1?
Why flash BlackHole 3.02E, if you have BlackHole 3.02F avaiable? --> http://www.vuplus-community.net/board/threads/black-hole-3-0-2-f-kodi-vu-solo4k.28780/
Even then is better, before connect your "malfunction device", upgrade your image.
You can update it by:
  • BlackHole image online update
or
  • By telnet entering the following command lines ( one by one ):
opkg update && opkg upgrade
reboot
Ok I hear what you are saying it just what other upgrade image do we have then BH 3.02F ? which is back on it now?
What i am trying to say you is that the image i refer in my previous post is the last one for your STB, that is 3.0.2F version. I´m quite shure that if you Flash your STB with this image, you probably have "updates", regarding some fixs.
So is better run an Online update or an update via telnet by entering the commands i said in previous post. This way you are completely shure you are running the last image modifications.
Depends.
The Solo 4K has ARM architecture while most other enigma2 receivers have MIPS architecture. You can have the drivers loaded for the device, but parts of enigma in the Solo 4K image will probably need to be changed before this device works with the Solo 4K image you have now. That is what it looks like to me from the crash log.
The Skywalker-1 may/may not work with other team images besides BlackHole using the Solo 4K. It will depend if the other teams have made the changes needed for the card to fully function. I suggest trying different team images and hope you find one that works or change to a device that is known to be supported using the Solo 4K. Several different teams support the Solo 4K.
I haven't a clue as to what you are trying to accomplish using the Skywalker-1 with the Solo 4K except maybe for the turbo dish channels? There may be other solutions available besides the Skywalker-1 if you care to share what you are wanting to do with it. Best of Luck ! EB
