HDaddict
Hello everyone.
I have a VU SOLO2, and I noticed a problem while playing large MKV files.
When playing a large MKV file, especially 1080p files, there's a constant freeze/lag each 2-3 seconds for a very short split of a second, so that the video playback isn't smooth as it should be. Audio is fine, but it is quite evident.
The problem isn't with the TV I'm using, as the files play fine using the built in media player of the TV, either using USB or using the DLNA server on the SOLO2, so it must be a problem with the decoder itself.
Currently I'm running BlackHole 0.1 usind Mediaplayer2, but this problem happened in earlier versions of blackHole and with any media player I used.
Has anyone noticed this? I can upload a video showing this if needed.
Thanks!
Thanks!
