I'm using the Black Hole 2.1.4 firmware. Unfortunately the YouTube TV plugin doesn't work very well. It is a little bit slow. It takes a lot of time to show a video. Often the video has freezes even if the connection is ok.
The receiver's hardware should be sufficient to support the Youtube plugin... so i cannot understand why i've got such issues. I've tried to use a swap memory on USB but it's unuseful.
Do i have to reinstall the YouTube plugin? How can i sort this problem out??
The YouTube TV plugin was already installed after the firmware re-flash with blackhole. I found it directly in the main menù. Unfortunately it works until I click in the video to watch it... But the only thing I get is a black screen...
I tried some tests... I saw that if I wait 3/5 minutes on some videos of 7-10minutes eventually I get the video. Maybe the app download the total video before to let play it. Is it any way to shorten the buffer/cache of the app??
