I have a VU SOLO 2. The problem I have is that having installed live football plugin from Blackhole server the resolution of the plugin is too high. All the boxes are very small. Any help would be appreciated. .....Geoff
It's to do with the skin your using on the blackhole image.... The author of the live football plugin needs to make changes it so that it shows properly when installed on a image using a HD skin, if you change the skin your running now to a non full hd one the plugin will show in normal size....
Thank you for your reply. I tried a few skins from the Blackhole server but ended up having to reflash the box as the dreaded green screen appeared and would not let me enter the box. I will just have to put up with it. Once again thank you for your help....Geoff
